get the engine in
  • Thread starter Thread starter blackjackbender
  • Start date Start date Oct 30, 2005
blackjackbender
36
  • Oct 30, 2005
well im trying to get my 302 back in and lined up with my c4 trans. I tried it by myself with no luck at all. should i make it so the engine tips down in the back so it matches the trans angle better? or if anyone has any ideas or tricks of getting the engine back in, trying to get it in tonight but will probably wait until my dad gets back into town monday.
thanks
Ty
N
nds03
166
  • Oct 30, 2005
its much easier with two people, just wait for your dad
69Rcode_Mach1
1,473
Salt Lake City, Utah
Oct 30, 2005
  • Oct 30, 2005
I second that, it is a pain in the ass to do by yourself. IF you don't have the tranny attatched to the back it shouldn't be too bad, but if its your first time just wait you could damage some stuff.
Cobain03
996
Lexington, Ky
Oct 30, 2005
  • Oct 30, 2005
haha my first time putting an engine in, i didnt have a engine hoist lol. we had a tractor with a lift bar on the back! haha it worked, jsut nto the best way to do it.
+1 on waiting for help. plus if you get annoyed, always got someone to calm ya down lol
hungrymonkey
White by Birth, Trash By Choice
12
108
Oregon.
Oct 31, 2005
  • Oct 31, 2005
jack up the transmission a little bit, so it angles up. then angle the back of the motor down a bit.
That should get the pins to align a little bit more with the bell housing.
Wait for it to clunk together and then let the jack on the trans down a bit and lower the motor.
when In doubt, curse. If that doesnt work, beat it with a hammer. If it stil doesnt work, Light it on fire.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Oct 31, 2005
  • Oct 31, 2005
Before you jack up the tranny, you might want to undo the tranny mount.
351LX
1,007
Regina, Saskatchewan
Oct 31, 2005
  • Oct 31, 2005
Take a couple of bolts that are 2-3" long or so and the same thread as the bellhousing bolts and cut the heads off.Thread them into the back of the block loosely and it will help line up the engine and transmission.Before you put the engine in make sure that the torque converter is fully seated and that the orientation of the torque converter studs matches the holes in the flexplate.When you finally get the engine mated with the transmission using the headless bolts, thread in a couple of bellhousing bolts loosely to lock everything together.Check that the torque convereter studs are going through the holes in the flexplate.If they aren't then generally there is still enough clearance that you can spin the motor or flexplate and get them to pop into place.Push the engine against the transmission and tighten the bellhousing bolts while periodically making sure that the torque converter isn't jammed against the flexplate.You should be able to wiggle the torque converter slightly back and forth even when all the bellhousing bolts are snugged down.If you can't wiggle the torque converter then stop as further tightening of the bolts can do damage and it probably means the torque converter isn't seated all the way in.I have installed a lot of engines by myself and the cut off bolt trick helps.Just don't thread them in too far as they can be a pain to get out later.
krash kendall
1,258
Aldergrove, B.C. Canada
Oct 31, 2005
  • Oct 31, 2005
You have the torque converter on the tranny and not still on the engine's flex plate, don't you?
D
Yet another v8 swap
  • dulcimerbob
  • Sep 19, 2026
  • 2 3 4
1974 - 1978 Mustang II Talk & Tech Yesterday at 1:04 AM
LILCBRA
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
