getting close........
  • Thread starter Thread starter 98COBRA281
  • Start date Start date Dec 18, 2008
  • 3
  • 4
First Prev 2 of 4 Next Last
BurningRubber
1,865
24
58
Dec 21, 2008
#21
  • Dec 21, 2008
  • #21
98COBRA281 said:
yeah lol, i dropped it in with the passenger side on, but the driver side has the slip joint in it, because the steering shaft goes throught the header, and it was a BIG bitch.
Gotcha mang.
What brand are they? They look pretty damn big, lol.
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Dec 22, 2008
#22
  • Dec 22, 2008
  • #22
BurningRubber said:
Gotcha mang.
there just cheapo flowtechs, they have 1-5/8" primaries, with a 3" collector, not to bad for 280 bucks........
Slow35th
37
#23
  • Dec 23, 2008
  • #23
98COBRA281 said:
no, i was going to get them flow benched, but i cheaped out, i didnt want to spend the 75 bucks
did they port the exhaust side at all?
98COBRA281
1,348
30
59
Dec 23, 2008
#24
  • Dec 23, 2008
  • #24
yeah, i did all the port work, and the exhaust ports are fully ported and polished too....
Slow35th
37
#25
  • Dec 23, 2008
  • #25
well i can tell you right now it will lose low end torque. 4.6 heads do not need porting on the exhaust side. you might make good power but with the lack of low end torque it might not seem faster. we ported a set of heads and used the same cams i have and lost big low end torque. even with a porting the intake side no porting on the exhaust side is needed.
98COBRA281
1,348
30
59
Dec 23, 2008
#26
  • Dec 23, 2008
  • #26
well i got it running, and put about 60 miles on it, but its not runnign to good, it doesnt want to idle, and stumbles a little bit, and i havent even brought it past 3k rpms yet..........
BurningRubber
1,865
24
58
Dec 23, 2008
#27
  • Dec 23, 2008
  • #27
Is it down on power? Any wierd noises?
I'd check and re-check all your vaccum lines and electric hookups to make sure nothing is missing.
You could also give the old IAC valve a cleaning.
Bring it past 3k and see how it does.
98COBRA281
1,348
30
59
Dec 23, 2008
#28
  • Dec 23, 2008
  • #28
well i cant rely tell if its down on power, because i know the tune is way out, and it needs a dyno tune bad, but no noises at all....
you read my mind on cleaning the IAC, ill do it after work tomorrow,
i did get it to idle better by turning it up to about 850-900 ( it still shakes the **** out of the car)
ill have to bring it up past 3k, but im still afraid of going WOT
BurningRubber
1,865
24
58
Dec 23, 2008
#29
  • Dec 23, 2008
  • #29
Well if you are worried about going WOT because of the tune and how its running, thats understandable.
I would get on it a little bit though, but I would ease into it just to see how it felt. Vary the RPM's a bit, it's probably a little late to do that procedure as the rings are probably near set now depending on what they are.
CobraRed_96_GT
1,421
UCSD/La Jolla
Dec 23, 2008
#30
  • Dec 23, 2008
  • #30
Why would you even risk it? Heads and cams leans out the mixture a lot, wait for a tune. No reason to put a new engine together to run it over-hot with a lean mixture while breaking it in.
Slow35th
37
#31
  • Dec 24, 2008
  • #31
its not gonna idle until you get it tuned. should have gotten a base tune before you started it.
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Dec 24, 2008
#32
  • Dec 24, 2008
  • #32
So when are you getting that bad boy tunned? I wanna know how the beast runs. Oh and do you have a plan for the ole' stocker(build wise)?
98COBRA281
1,348
30
59
Dec 24, 2008
#33
  • Dec 24, 2008
  • #33
with in a month or so, i want to get about 500 or so miles on it, i have only brought it to about 3500 easy, and when it gets a little over 3k you can hear the longtubes start to scream
oh, and for the stock motor, i have BIG plans, all forged, and eighter big bore or a stroker..........
98COBRA281
1,348
30
59
Dec 24, 2008
#34
  • Dec 24, 2008
  • #34
well i just took it out to dinner, and it now has 73 miles on it, but it does stumble around 2-3krpms, when i give it a little gas under load (2nd-3rd gear), i can rev it and it does not stumble at all, is this because of the tune?
im still running the plugs from the old motor, they have about 7k on them, but i think im going to get new ons, should i stay with platimun(sp?) or go with copper plugs? and should i still run the stock gap?
:SNSign:
BurningRubber
1,865
24
58
Dec 24, 2008
#35
  • Dec 24, 2008
  • #35
I'm not saying he should go WOT...
Just saying he should gradually bring it past 3k and see how it acts. Getting on it for a second or two not WOT won't hurt to see how it is acting above 3k...
98COBRA281
1,348
30
59
Dec 24, 2008
#36
  • Dec 24, 2008
  • #36
heres a vid of one of the first start ups, it was open header, and loud as hell, thats my neighboor that came over to check it out, because he could here it inside his house....... lol
CobraRed_96_GT
1,421
UCSD/La Jolla
Dec 24, 2008
#37
  • Dec 24, 2008
  • #37
Your need to run a colder plug with a closer gap. Like a 22C or 22P - look for a AGSF
98COBRA281
1,348
30
59
Dec 24, 2008
#38
  • Dec 24, 2008
  • #38
thanks, why colder?
what brand of plug is that? and what should i gap it at?
BurningRubber
1,865
24
58
Dec 25, 2008
#39
  • Dec 25, 2008
  • #39
That sounds sick cammin away man.
Definatly get it tuned soon though, it's running noticably rough in the video... but I will bet you thats gonna clear up with a good tune.
Slow35th
37
#40
  • Dec 25, 2008
  • #40
you guys are funny. a tune will not clear it up especially on an n/a car. if the car was blown a tune might clear things up.after my cam install it ran fine. something else is wrong. double check everything. once again the car should run fine, it may not idle but will not miss and stumble as described.
  • 3
  • 4
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 19, 2026
squeak93
N
Dyno Issue with 2015 GT
  • Nickos.Ford
  • Jul 11, 2025
  • The Welcome Wagon
The Welcome Wagon Jul 11, 2025
Nickos.Ford
N
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
M
  • mnky99
  • Sep 5, 2025
mnky99
M
A
2020 Ford Mustang GT P0036, P0138, P0141 02 sensor help
  • AmkoA
  • Jul 29, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 5, 2025
skkrtis
