Getting DRs before axles.
  • Thread starter Thread starter Dbeck002
  • Start date Start date Sep 11, 2005
Dbeck002
710
South florida
Sep 11, 2005
  • Sep 11, 2005
I want to get a set of Nittos or MT streets. Will my axles hold up?
Mods are AFRs, TFS1 cam, ported GT40E, 3.73s and all the bolt ons.
Lets say i make 300 rwhp, can my stock axles hold up to a launch on DRs?
jaymac
995
Northern Mass
Sep 11, 2005
  • Sep 11, 2005
there is no "be-all, end-all" answer to that question. Logically, they should, but there are a million variables. 5 speed, AOD? How many miles? Torque Converter if AOD, What stall? 5 speed, what launch RPM, what kind of clutch (more for resistance to slipping than rear-end related)? What kind of front and rear suspension?
My buddy has a stock rear end w/ 4.10's, and went through a season and a half of mid 12's on MT ET Streets and high RPM launches w/ a 5 speed.
He's never broken the rear, but he has ripped seat blots out of th floorpan during launch.
Like I said, there are a million different variables, and no car will react the same.
They "should" hold up, but then agan, I won't be the one payin for the reapir bill if anything DOES happen
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 11, 2005
  • Sep 11, 2005
I have dr's in a lower 12 second capable car and have had them for about 10,000 miles or so with no problems. I'm not worrieda bout the axle's going.
rd
3,316
63
109
Ocean Springs MS
Sep 11, 2005
  • Sep 11, 2005
I can launch on DRs with 4.10s in my 7.5 in axle, 28 spline stockers, and live. With spray.
I have a 2800 converter, so it does not hit the tires real hard. 1.80-1.90 sixty foots consistently.
Been ok for 2 years.
Dbeck002
710
South florida
Sep 11, 2005
  • Sep 11, 2005
T5 with 3.73s...
Launch as high as possible whilst keeping traction, say 4k.
I dont know what kinda clutch, i think stock.
Has 150k miles on the odo.
I just want to know sh1t wont start breaking because i intend to pull the wheels off the ground.
notchback
1,950
St Clair Shores MI
Sep 11, 2005
  • Sep 11, 2005
keep your 60 foots over 1.5 and your good to go.
launches at 3500-5 k are fine at your level.
i have yet to do axles on a car and i've had 6 stangs.
i used to launch my old coupe at 4k on nitrous out of the hole.....1.6x 60's and 12.50 et's and never had an axle issue
retro50
191
Plymouth,MA
Sep 11, 2005
  • Sep 11, 2005
It will only last for so long. I've broken two stock axles on the driver's side. My car runs 12.50's with a t-5 and 4.30 gears. The 60's were in the 1.70 range. I launch at 4500 r.p.m. on E/T Streets. I finally went to a Detroit locker and 31 splines in the same housing with the same gears. Havent broke one in the last four years. Your on borrowed time. Just think if you break one at the other end at speed what will happen. I was lucky it happened at the line and I didn't move at all. Some times they will break early on and they will come out well into the run. That will be a scary ride.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 12, 2005
  • Sep 12, 2005
I personally wouldn't worry about it. The rears on these cars can take some abuse...I have never worried about my rearend screwing up...literally. And as some can attest on here...I'm paranoid
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Sep 13, 2005
  • Sep 13, 2005
My S/C Cobra had a stock rear end with 4.10 gears andNittos . 414RWHP 366RWTQ. I have passed down the drag strip about 50-60 times doing a burnout before about 15-20 runs. Plus I am rough on the street and horse around a lot. My axles were fine, the only thing that happen was I burned out the clutches in the posi unit. When I had that fixed I upgraded to 31's and an Explorer 31 spline posi carrier. You will be just fine with 28 splines, just get the posi unit bulit tough.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
R
8.8 rear end for '67 coupe, shortened - next steps
  • rubendenver
  • Dec 15, 2024
1965 - 1973 Classic Mustangs -General/Talk- Jan 8, 2025
GOvert
G
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
