getting slight power flucuation with votech
stanggt00
371
baltimore md
ok this is my first superchaged car guys so maybe this is normal
when driving and not in boost giving the car steady gas say 60mph
i can feel the car sligthly surging almost as if i had the ac on in the car
nothing major but i can notice it
now i know that a superchager puts some drag on the car because even if your not in boost your motor is still turning the charger.
and secondly if the car sits to the point were its cool (not at operating temp.)
the car just dies at start up
but if i give it a little gas for 2-3 secs then it idles fine
but like i said if i just turn the key to start it up it dies
also if its warm it does start right up but the start up is kinda lazy like (not a strong start-up)
another question i have if the battery is removed from the car for say several hours will the tune i flashed with my sct be removed and the car returns to default
i was just wondering because i had a clutch put in about aweek ago and they had the car unplugged for a few hrs
i was not sure if thats why the car was idling funny so i reflashed it
The surging is probably the bypass. My car does it as well, it should go away once I finally put a mini-race on. FWIW, I've noticed it's wose w/ humid weather.
I'm not sure about the startup issue. How long has the blower been on? It may be an IAC that went bad, but I'm not sure.
As for the flash, you're fine w/ the battery unhooked. The tune will stay.
I have a Procharger and it does the same things.
A slight surge at 60mph. Pedal to the floor I don't feel any surge though.
In the mornings, my car also takes 2 seconds or so to start versus a second when its hot.
Not a big deal in my opinion.
