My car is approaching 100k and I want to keep her running as long as possible. I've regularly changed the oil myself every 3,000 miles or so with synthetic, either 5W or 10W-30. About 5 months ago I had a shop change the oil for me. They used Pennzoil, regular oil. I checked everything afterwards to make sure they didn't screw me. Everything was fine and like usual there were no problems. About 2 months ago I changed my oil again, going back to synthetic 10W-30and just recently (within the past 2 weeks) my car seems to be spitting white smoke. Its more white then blue and it only happens if I kinda get on it from a stop or when I mash it on the highway. While cruising theres nothing. My roommate is telling me that you can't switch back to synthetic after using regular oil because the molecules or minerals
are smaller in synthetic oil which will lead to some of the oil leaking through the seals. Oil pressure and water temp are reading normal and I just checked the oil and it's light brown, but its about halfway between the min and max on the dipstick. I put a little more oil in, like 1/6th of a court. It's only a little bit of smoke but I'm worried that this could be a bigger problem then I think. I plan on going changing the oil with regular oil from now on and using a heavier weight. I had a similar problem with my 96 monte carlo except it would smoke out the neighborhood whenever I turned it on, and it ended up being a blown head gasket. I just need some reassurance that some oil burning is normal for a car around 100k and won't cost me 2 months of fulltime work to fix it. How do I go about fixing this?
