Gizzmo Electronics - Boost Controllers and More
statRacing
$225.40 ON SALE
Order here: Gizzmo Boost Controller
Gizzmo IBC: Intelligent Boost Controller - p/n G0920
Four Boost Memories
Adjustable boost up to 2bar (29lb)
Fast RISC Processor Technology
Real Time Digital Boost Gauge
Extruded Alloy case
Simple 2-wire installation
Suits internal or External Wastegates
Comes complete with all Hoses and Fitting
The Gizzmo IBC (Intelligent Boost Controller) represents the ultimate in accurate, simple to operate, and easy to install Computerized Boost Controller. Because all the thinking is done inside the IBC, You will not require an Engineering Degree to operate or fit it (Promise!). With the Gizzmo IBC’S precision 29Lb MAP sensor, high speed RISC processor and powerful MOSFET solenoid driver, and the fastest, most powerful solenoid you can assured that your Gizzmo IBC has the quality, resolution and accuracy that you need for your turbocharged vehicle.
$299.99 ON SALE
Gizzmo MS-IBC: Multi-Scramble Intelligent Boost Controller p/n G0921
Adjustable boost up to 50lb (3.5bar)
Multi Scramble Boost Control
Remote Scramble/Boost Memory button facility
Over-Boost warning
Selectable open/closed loop boost control
6 Boost Memories
40mhz High Speed RISC Processor
Black Extruded Aluminum case
Blue 7 segment LED display
White backlit buttons
Real Time digital boost gauge
Simple 2-Wire Installation
Suits Internal or External Wastegates
Comes complete with all fittings
In developing the MS-IBC Boost Controller, the aim was to design and engineer a boost controller that would cater to the serious drag racing professional, whilst still being quite at home on the streets. We succeeded.
Dsport Magazine Hit's 1,031 Horsepower with the MS-IBC!
The MS-IBC Boost Controller is packed with the serious features that can be utilized in the real world of drag racing like 3.5 bar of boost control, a clear digital boost gauge with an over boost warning and a remote Facility to either toggle the high speed boost change memories or operate the Gizzmo Multi-Scramble feature.
Gizzmo’s Multi-Scramble Boost Controller takes the conventional scramble feature one step further. A conventional scramble allows the user, upon pressing a button, to set a fixed amount of over boost and time duration e.g. 3lb extra for 5sec. Gizzmo’s Multi-Scramble function allows the user to operate the button again before the scramble time has completed adding the same amount of boost again and refreshing the time duration.
All of this plus closed/open loop modes packed into a great looking boost controller that is so easy to fit and operate.
