My friend has a 97 convertable and the rear window is coming loose. is there a special type of glue that we can use to seal it, or do we have to take it to a window shop? any suggestions would be greatly appreciated?
you can try getting some gorrilla glue from Home Depot...its good on cloth, glass etc. Maybe run a bead of silicone inside before you glue it to try and seal it from water. Its worth a shot. When mine was bad most Pro's I talked to basically told me to replace the whole section cause it won't stay sealed...
