GM HEI trouble update
  • Thread starter Thread starter NKau
  • Start date Start date Jan 30, 2006
NKau
1,346
Jefferson, WI
Jan 30, 2006
  • Jan 30, 2006
Well, the ignition problems in my truck ('86 chevy silverado, 305) have gotten quite a bit worse. Now, upon startup, the truck will run OK while in cold idle, but has an audbile miss. After the truck warms up, the engine will not stay running if partial throttle isn't applied. It will miss progressively worse as you lean out of the gas, and flat cut out once you get off it; conversely it seems to run just fine at higher rpms, or under load when you lean into the gas. Supposedly symptoms of a bad HEI module indicate that you should be having problems at higher rpm/under load; opposite of what I have going on with mine. It's done this on occassion in the past, but not to the extreme that it can't idle on it's own. I'm kind of lost here..........
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jan 30, 2006
  • Jan 30, 2006
Only time I had problems with missing on my old F-body (HEI) was due to a bad plug wire. It was new out of the box MSD and caused a serious miss.
Another issue I had was a poor 12V connection the HEI coil which led to random no start issues.
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
M
03 GT Misfire at idle only, calling all experts!
  • midnight03
  • Feb 27, 2024
1996 - 2004 SN95 Mustang -General/Talk- Feb 27, 2024
midnight03
M
H
'86 New Turbo Build First Start/Idle Trouble. Full Tune specs attached
  • Heffay
  • Jul 10, 2022
  • Digital Self-tuning Forum
3K
Digital Self-tuning Forum Jul 12, 2022
Heffay
H
