  • SN95 4.6L Mustang Tech
Going from TR3650 to 4R70W?
  • Thread starter Thread starter jivepepper
  • Start date Start date Dec 26, 2008
jivepepper
776
Under a Sombrero. in WV.
Dec 26, 2008
  • Dec 26, 2008
If I decided to get an auto ecu and auto trans harness for a 4r70w what else would I need to make it work like stock? I of course know I would need another tune. What about the clutch switch that allows the starter to engage?
Thanks.
hotmustang331
2,967
Bastrop,TX
Dec 26, 2008
  • Dec 26, 2008
You should only need a tune.
The clutch switch you just bypass to be always on....people do it now so they can start in gear incase their car wont fire up and they need to move it.
C
califsp
22
  • Dec 26, 2008
If you change out the ecu you'll run into a problem with the PATS. Better to have the original ecu flashed by a ford dealer for $100. You'll need a pedal set, shifter with cable, fluid lines from trans to cooler, trans cooler and you're drive shaft may need to be changed. It's better to sell your car and buy a cheeper one with auto.
jivepepper
776
Dec 26, 2008
  • Dec 26, 2008
I will also have the pats turned off. I guess with a new wire harness the back up lights should work too?
squeak93
2,357
419
164
Joplin, Missouri
Dec 26, 2008
  • Dec 26, 2008
Sell the car and buy one with an auto in it? What....... It can and has been done before. Sounds like ur already aware of the pats issues, so that takes car. U will need a tune and all the above mentioned parts but no reason an average joe can't do this in his garage.
theseeker411
14
Chattanooga, TN
Dec 26, 2008
  • Dec 26, 2008
Too bad you aren't closer to TN. We could just swap transmissions between our cars. I want to swap my 4R70W to a 5 speed.
3,287
24
69
Broke
Dec 26, 2008
  • Dec 26, 2008
I'm in MA and might consider a straight swap. How many miles on the trans. Does it have issues. I have a friend who would do the work.
Still not 100% I want to do the switch though. I might well buy a Mercedes C class this week. Have to see if I go ahead with that or not.
jivepepper
776
Dec 26, 2008
  • Dec 26, 2008
Thanks I already have one coming.
jivepepper
776
Dec 26, 2008
  • Dec 26, 2008
squeak93 said:
Sell the car and buy one with an auto in it?.
To much money in this one.
04YELLOWGT
1,135
Indiana
Dec 26, 2008
#10
  • Dec 26, 2008
  • #10
So you have a 4R70W coming? Is it already built or are you sending it out? Are you Stalling it too?
You should be running mid 10s now with out a problem.
jivepepper
776
Dec 26, 2008
#11
  • Dec 26, 2008
  • #11
I really need the help, I just can't get any faster with the manual. Part of it is my arthritic condition. Plus it will be easier for me to drive on the street.I will just use it stock for a while and see how well it hold s up.
This is my list as of right now.
$300.00 Used 4R70W shipped with 42k from a 2003GT ( comes with cable, position switch, cross member. harness, all sensors, TQ converter, and dipstick)
300.00 Used TQ Converter 4000 stall (Ultimate Converter Concepts)
$80.00 jmod
$44.00 Summit universal trans cooler.
$54.00 Ford racing flex plate.
$6.00 Toggle switches
$23.00 Auto console bezel
$75.00 Used stock shifter
$80.00 Filter and fluids.
$00.00 returning a ECU I bought earlier for a manual in exchange for a auto ECU.
$962
04YELLOWGT
1,135
Indiana
Dec 27, 2008
#12
  • Dec 27, 2008
  • #12
$80.00 jmod
$962
How much power are you making again?
If the trans is going to be apart for the jmod I would just have it built while your at it. Seriously no one could belive that I was on the stock tranny when my car was making like 425(underrated) rwhp when I was running 11.6. I know your making more than that. Trust me dude the I don't see that car making many runs before you start having problems.
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
C
5r55s auto to TR3650 Manual swap 4.0 V6
  • Ceskz
  • Feb 24, 2025
  • 2005 - 2014 Specific V6 Tech
2K
2005 - 2014 Specific V6 Tech Mar 27, 2025
89ripper
Fox Traction control
  • Sparky714
  • Nov 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2026
Sparky714
