  • SN95 4.6L Mustang Tech
Going N/A No stones. Need adv
  • Thread starter Thread starter gt-351
  • Start date Start date May 17, 2007
G
gt-351
136
va
May 17, 2007
  • May 17, 2007
Ok, I'm going at this blind so to say. I have a 99 gt. 4.11s, long tubes , stock auto, under drive pullies, JLT cold air, Pro elbo. I have a extra set of PI heads and wanted to send them off to have a cnc port job. Can I shave these heads to get more compression? How much? I'll be running pump gas.
Second, New cams? I saw a write up on Crower cams and they made good power. What have you guys had luck with the N/A way? I know a blower is better and will save me money but this is how I'm going at it. Thanks
hotmustang331
2,967
Bastrop,TX
May 17, 2007
  • May 17, 2007
4.11s?
Um send the heads to fox lake, or MMR for porting and they will allow them to REALLY flow.
Id get some custom grind cams from VT engines.
40th GT
916
Lawrenceville, GA
May 17, 2007
  • May 17, 2007
Yeah you definitely have 4.10s unless you have a GM rear end assy.
Brute03
232
  • May 17, 2007
gotta be an ex-GM guy, haha
G
gt-351
136
va
May 17, 2007
  • May 17, 2007
Well , now that we all know about my ring and pinion gears..... Will I be able to mill the heads to get a smaller cc like the push rod motors or will it mess with the chains?
How much more power should I look for with stock pistions and a good port job/cam combo?
Superhereaux
chicks make me feel inadequate
538
South Texas
May 18, 2007
  • May 18, 2007
no milling of the heads period, at least not enough to make a difference. the timing chains won't like it
stock pistons with cnc heads and cams? with ALL the bolt-ons including a new intake manifold (trickflow maybe), full exhaust, aggressive tune and alot of debt you can break 300rwhp (maybe)
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
May 18, 2007
  • May 18, 2007
you should definately be at or above 300 with what hereaux listed.
if youre gonna go full on n/a id suggest raising the compression and/or a stroker. or you can do all the **** listed above, and when that isnt enough, you can add juice.
G
GettinThere
553
Central Texas
May 18, 2007
  • May 18, 2007
I wish I had the answer for you. Maybe there is a head gasket that will reduce the volume of the combustion chamber, but not by much. Maybe forged pistons that have less than the stock 17cc dish (as well as forged rods) are what you need. Good luck.
the98stang
2,408
Clovis, CA
May 18, 2007
  • May 18, 2007
thomas91169 said:
you can add juice.
Or a blower
MaxedGT
304
Surrey BC Canada
May 18, 2007
#10
  • May 18, 2007
  • #10
Auto? High stall torque converter! especially if you plan to change the cams.
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
Motor given to me and I’d like to rebuild it what do I need to do
  • Creomod
  • Dec 14, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 16, 2024
AeroCoupe
Fuel ā€˜88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
