set an 12 noon apointment for friday at the dyno tuner. lets see who is the best at estimating hp by looking at a list of mods.
its a dynojet thats only a couple months old. my mods are as follows:
302c.i.
K&N air filter
Pro-m 80mm MAF sensor
Professional Products 70mm throutle body
Professional Products 70mm EGR spacer
Professional Products intake manifold (upper and lower)
Mac equal length shorty headers
Summit Racing catless H-pipe
Flowmaster-Delta Flow mufflers (with dumps)
NGK spark plugs
Mr. Gasket high flow 180 degree thermostat
electric radiator fan
MSD 8.5mm super conductor spark plug wires
MSD TFI ignition coil
MSD 6AL ignion box
Powerslot slotted rotors
Hawk Racing performance pads
Edge Racing 3200rpm stall torque converter
B&M transmission cooler
AFR 165 aluminum heads (58cc)
Scorpion aluminum roller rockers 1.6
hardened push rods
Trickflow 3/8" heat spacer
Strange 10 way adjustable rear shocks
UMI rear upper control arms
Mega Bite Jr rear lower control arms
adjustable pinion snubber
weld in sub-frame connectors with seat support
4 cylinder mustang front springs
strange 10 way adjustable front struts
Ford Racing 3.73:1 gears
Ford Racing 31 spline limited slip differencial
Moser 31 spline hardened axels
Torque link
Kirban adjustable fuel pressure regulator and gauge
T-rex inline fuel pump
Ford Racing 42# injectors
255lph fuel pump
battery relocated to trunk
Load Boss 3G 150A alternator
Vortech S-trim supercharger (3.00" pulley)
AFM methanol/distilled water injection
UPR boostmaster pipe
programmable engine management system (PMS)
STOCK BLOCK AND ALL INTERNALS (INCLUDING CAM)
theres the info, lets hear those estimates
302c.i.
K&N air filter
NGK spark plugs
MSD 6AL ignion box
hardened push rods
Torque link
255lph fuel pump
), SC-Trim, and 5-speed. I made 405rwhp @10psi so I would hope with your meth, S-Trim, and AFR165's that you should eclipse the 400rwhp mark very easily. I'm gonna go with 435rwhp 416 lb-ft/tq.
