Going To the Junk Yard tommorow.
Steve69
233
Im looking for a 3G alternator. They say they have some from Taurus's.
My question is Radiator Electric Fans. I did a search and I couldn't fine one
on the Junk Yard Fans. What Year and Model should I be looking for a good
doner for a 69 Mustang. Mounting hardware? should I be looking for this
or buying new? Who sells it? Thanks for the Help.
Steve69
That write-up is for a Fox body. I bought a Taurus fan at the Junkyard a while back ($40) and it pulled air like crazy. Only problem - It wouldn't fit. It's about 4 1/2" thick and I only had 3 1/4" to work with. I sold it on ebay ($40).
Your's might have more room, just something to think about.
Just so I'm clear, you are looking to get a 3G alternator from a Taurus? Is it correct that a 3G alt from a Mustang will not fit your 69 without modifications? And this is because its fatter than the Taurus alt?
The Taurus fan is meant to be a puller. I dont think you would get anywhere near the airflow if you tried to reverse the polarity and use it as a pusher. (if it would even work - or FIT for that matter)
Plus what Capt Dan said.
