Going to the track in an hour: Tips?
  • Thread starter Thread starter Maza4ever14
  • Start date Start date Apr 26, 2008
Maza4ever14
187
Bay Area, CA
Apr 26, 2008
  • Apr 26, 2008
Like the title says I am going to the track in an hour. Sacramento Raceway to be exact. Well this will be my first time going driving a 5 speed. I went all the time with my auto 04 and did pretty well in that car but this is a new world to me.
Right now I have all 4 tires(Stock 18" BFGs) at 40 psi for the drive up. What should i lower the rears to? I dont plan on doing a burn out seeing im on street tires and wont really help me too much.
How bout launching? Should i rev to 1500 and go up lil by lil? Should i ease the clutch or just dump it?
Any help or any other tips would be VERY appreciated.:SNSign:
DarkFireGT
Playing with my wife's really makes me want one.
692
10
89
East Moline, IL
Apr 26, 2008
  • Apr 26, 2008
Drop the rears to 22-25 PSI, go around the water, and spin the tires just enough to clean the rocks and crud off of them. Hold on the line at 1500-2000 and slip the clutch for the first 5-10 feet.
If you have 3.31's, you can probably powershift 1-2. If you have anything lower (numerically higher), you won't want to powershift 1-2 on stock tires, but you should still be good on the 2-3.
gashog
139
Fresno, CA
Apr 26, 2008
  • Apr 26, 2008
Powershifting... what exactly is this? Not lifting the gas between shifts?
Maza4ever14
187
Bay Area, CA
Apr 27, 2008
  • Apr 27, 2008
disappointing. Just got back. best run was a 14.4@102 and i think i messed up my clutch, first gear seems weird or maybe its just me.
DarkFireGT
692
10
89
East Moline, IL
Apr 27, 2008
  • Apr 27, 2008
Yep, that's correct. On street tires, it's pretty much impossible to do that with 3.73's or 4.10's during the 1-2 shift. Definitely not safe. But 2-3 should be ok.
Don't feel bad. Aimee drives our 2005 at the track. With the mods that are done to it, it's good for about 12.5, but her best is still about 14.2.
My worst is 15.1@67MPH lol. I toasted my clutch a bit during the burnout when moving into 2nd gear. Wouldn't go into 3rd gear during that run because of that. We all end up with things like that every once in a while. But I let the car cool down for an hour and ended up running another 13.5 the next run.
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Stand alone vs chip tune (for noob)
  • nicholase
  • Jan 2, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2025
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
L
1986 Manual Swapped 5.0 Misfire + Other odd issue
  • LinkedInLincoln
  • Aug 12, 2024
  • Other Auto Tech
  • 2 3
3K
Other Auto Tech Sep 11, 2024
