Well thanks to all the advice, I've decided on centerforce df clutch kit, next question is flywheel? Centerforce or Ford racing? Quite the cost difference...best place to get eitehr one?Thanks
Either one should be good. If you have the Ceterforce clutch then you might want to stick with there flywheel. I got a Ford Racing one that should be here tommrow, I got it from Summit. I think they have the Centerforce Flywheel also.
I am using the ford flywheel with my KC. when i had a centerforce DF i was also using a ford flywheel
in case your wondering why i don't have my DF anymore I will give you the short story..
My car had the rear main seal retainer spring a leak and wiped the clutch out. the bellhousing was filled with a combo of oil/clutch. and because of cost i had to go with the king cobra this time around.
