Good and Bad?
tjmaxx
157
Can someone tell me the advantages and disadvantages of carberated stangs because I am looking at a 84 lx but am not sure if I should get a newer fuel injected car.
Pros:
They are Cheap to work on
less Computer sensors to fail
Just as fast as EFI
Just as reliable as EFI
Cons:
Gas mileage in a cruiser will suffer slightly
Cold starting can be an issue
Supercharging is more expensive
you will need to convert to dual exhaust (?)
Brakes are slightly smaller
Transmission (stock) is weaker than newer units
There is nothing wrong with carb'd motors. I have built up two of them in my life time so far. This mustang will be my frist EFI build. You should also know that a lot of EFI guys convert to Carb because they are generally cheaper to build up.
I have had my carbed 79 5.0 since 1981 and driven it well over 200,000 miles, with several dozen dragstrip runs. Current setup will get 21 mpg on the highway w/o overdrive. They work just fine. 84 is a good year to get, as I think it includes the 4v carb stock, and most other stuff is forward compatible.
Modular2v said:
there are disadvantages to having a carb? i converted my fuel injected motor to carb
Yes. In several areas of the country you cannot title a car converted from fuel injection to carb because of smog inspections. No title = no license plate for the area you are living in. That can be a problem. Not to mention if you get stopped at a roadside inspection you can be fined, your vehicle impounded and even go to jail. It is a federal offense to remove the polution control devices from a vehicle that was equipped with them from the factory.
lol i know there are, i guess i should have emphasized the sarcasam :nice:
