  • 1994 - 1995 Specific Tech
Good bye tweecer
  • Thread starter Thread starter must b a stang
  • Start date Start date Dec 23, 2004
1 of 2 Next Last
must b a stang
48
  • Dec 23, 2004
After 2 weeks of working with tweecer i am sending it back . tried everything possible and it is causing error codes in my cars eec and the car ran terrible.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Dec 23, 2004
  • Dec 23, 2004
I didn't know they excepted returns.
must b a stang
48
  • Dec 23, 2004
U have 30 days from the day U bought it as long as u send it back in the orignal package .
VibrantRedGT
424
154
Boca Raton, Florida
Dec 23, 2004
  • Dec 23, 2004
Damn I should have done that with mine. I sold mine after two weeks to Jesse on the boards here. Went with a PMS instead.
must b a stang
48
  • Dec 23, 2004
was thinking of going with a after market computor .
VibrantRedGT
424
154
Boca Raton, Florida
Dec 23, 2004
  • Dec 23, 2004
The kit is way tooooooo expensive. I believe a Tweecer R/T is still cheaper.
must b a stang
48
  • Dec 23, 2004
My tweecer/rt did not like my mods or my B303 cam .
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Dec 23, 2004
  • Dec 23, 2004
Lets all put credit where credit is due. The TwEECer is nothing more than a device that allows you to change the calibration parameters of the EEC-IV.
Saying "My tweecer/rt did not like my mods or my B303 cam" is not accurate. What you mean is that you were unable to adjust the calibration on the EEC to work with your setup.
The TwEECer is only as good as the person working with it. Some people will have more luck with tuning devices that take away tuning features in order to make it simpler. That is okay.
Dave
95YellowGTbeasT
605
South Carolina
Dec 23, 2004
  • Dec 23, 2004
it likes my b303 i could have even sent u an config to get u started
Nick
must b a stang
48
#10
  • Dec 23, 2004
  • #10
The tweecer/rt is the worst thing i did to my car with all the money i spent with out taking short cuts and being on the phone with c&l profromance and tring everything and all suggestions there is no one set up that worked , even the J4J1 with only changing idle settings caused my car to run poorly , the time i put in to tweecer is not worth the aggravation .
Nucking Futs
158
Franklin TN
Dec 23, 2004
#11
  • Dec 23, 2004
  • #11
When I get around to swapping the engine out I am going with an AEM unit. That thing is awesome. The more I read and learn I think that will be the best way to go.
type911
169
Port Charlotte/ Boston
Dec 23, 2004
#12
  • Dec 23, 2004
  • #12
Love my tweecer. Think I have it damn neer as good as it gets. (as far as a tune goes) Sorry your experiance wasn't as good. Did you change the fuel table stabalized OL at all. the j4j1 runs real rich found that out on the dyno. Played with the table and now have a 13.0-13.5 afr at WOT. Car idles perfect even with the AC on with my TFS cam. Im sure if you ask around someone has a similar set up that would send you a good tune to start with.
BlackVert
5,589
9
98
Bethesda, MD
Dec 23, 2004
#13
  • Dec 23, 2004
  • #13
i love my tweecer. there is a big learning curve, but i think it is worth it. now i can modify my tune myself when i upgrade parts.
sorry to hear you are giving up on it. good luck with your other tuner.
where do you live? maybe there is a tweecer guy nearby who can help you out.
raven69david
112
San Antonio, Texas
Dec 24, 2004
#14
  • Dec 24, 2004
  • #14
User error, not TwEECer error. All the stuff in my sig made my car idle and respond horribly. After finding someone who was an expert at tweecing, he sent me a file that i custom tailored to my liking and the car now runs almost stock. Good luck with other tuners as they are more expensive.
must b a stang
48
#15
  • Dec 24, 2004
  • #15
If there is anyone that can give me more info on this tweecer/rt i will give it another try , i dont like giving up but this thing is driving me crazy , or if there is someone that has a file i can start with that would be great . I live in NJ and if there is someone close to me that could help even better .
greenlantern
265
St Louis Mo
Dec 24, 2004
#16
  • Dec 24, 2004
  • #16
See this is what I didn't want to have to deal with. Don't get me wrong I understand that the tweecer is a great way to modify your computer but I went for the A9L conversion instead. Put it in and forget about it. Way better performance that the stock T4MO and the J4JL.
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Dec 24, 2004
#17
  • Dec 24, 2004
  • #17
It is great that worked for you. Some people still end up with driveability problems even with an A9L, so it could become an expensive option fairly quickly, if you end up having to get a tuning device anyway.
Really, the TwEECer isn't hard to use, I think some people try to change too many things at once. It is difficult to dig yourself out of that hole if it turns out to run like crap, since you don't really know what to fix.
I strongly believe that newbies should get a stock J4J1 calibration, modify the MAF curve to match their setup, and set the injector scalars to the correct values. And that's it. For 99% of combos, that should run like stock. It will not make the best horsepower, but it should be smooth. Then go from there, always keeping the base calibration in position 1 so there is a fallback.
Dave
type911
169
Dec 24, 2004
#18
  • Dec 24, 2004
  • #18
You hit the nail on the head. I started out with the J4J1 as a base tune and As I learned I added to the tune and can say the car runs pisser.
must b a stang
48
#19
  • Dec 25, 2004
  • #19
I did try the basic changes first and had no luck , tried the MAF transfer and injector slopes also called C&L which makes my MAF and also had no luck with tring what he said .
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Dec 25, 2004
#20
  • Dec 25, 2004
  • #20
Part of the problem there is C&L. They do not believe you should tune your computer, their opinion is that the so-called "calibration" they provide with their tubes is better than anything you can do with a computer. That's why I bought a Pro-M MAF instead, because it comes with a flow sheet .
One thing also to consider is that if you cannot get a basic J4J1 setup to work smoothly, and you know for a fact that the MAF and injectors are dialed in correctly, then it is possible (I would say probable) that something is broken. You can't tune out problems that are due to a malfunctioning part, you have to fix them the old-fashioned way. EEC tuning is for when everything is functioning properly.
Dave
1 of 2 Next Last
  • brandyn200
  • Jun 20, 2026
AeroCoupe
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
