good cam for a neraly stock set up?
  • Thread starter Thread starter lincoln+ford
  • Start date Start date Jul 7, 2009
lincoln+ford
195
  • Jul 7, 2009
Okay ive got my 331 lx mustang im building up but for my daily ive got a 91 Lincoln Mark VII witht he 302 auto.For mods ive got
Shorty headers
No cat hpipe
blowmasters
gt40(explorer) upper and lower
sn95 fuel rail
accufab AFPR
and stock e7's was wondering how a trick flow stage 1 cam would go with that setup the cam is out of my 306 low compression motor from the lx.So it would be a free mod just wondering if it would be worth it and what would all be needed to throw it in.Like Do i have to adjust the rockers now?Or do i still just torque them down?
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Jul 8, 2009
  • Jul 8, 2009
You really should just leave the stock cam in there, because any cam you put in there will not work well with your combo. If you at least changed the heads to say some iron gt40's you could use a small cam like a B or E cam. But, just throwing a cam in there would through you combo way out of whack. If you really want to throw a cam in there you could go with a B, E, or tfs stage 1 and the car will still be street-able, and you may even notice a power band shift but it just wouldn't be optimal for the heads and intake you will be running.
At least that is what most people will tell you. I got my car stock with a B-cam in it and flowmasters and it pulled like a mother f'er and sounded MEAN, so would I have taken the cam out and gone back to stock, hell no, but I don't know if I would have gone in there and changed the stock cam.
Cam's themselves aren't too expensive, but you need to get through a lot of things to change them so you mine as well replace those things, ie. timing chain, water pump, timing cover seal, and obviously will have to change all gaskets. But changing those things isn't a bad thing so if you can afford the extra stuff go for it. Most people will also advice you the cam and check p/v clearance on YOUR application, you shouldn't have a problem with the tfs cam but there are many variables in each engine that can change it.
Are you going to be running stock rockers or RR's?
WAIT is this for your Mark VII or 331?
V
v8only
2,378
22
49
Jul 8, 2009
  • Jul 8, 2009
the stock HO cam isn't a bad piece.
even with gt40 heads, it's still a good match.
leave that stock cam in with your stock heads, you're just begging to lose low end by swapping out a cam.
if you get gt40 heads, I'd suggest the tfs 1 cam.
I've got a b cam in my 66 mustang, and I'm not sure I like it...it opens up like a ****ing vtec engine at 3500 rpm's +, but sucks down low. the tfs 1 cam had a much better torque curve.
blackstangt
460
ny
Jul 8, 2009
  • Jul 8, 2009
do you have supporting mods for what?
sub-frame connectors
mass air/throttle body/egr spacer
These would be better investments...
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Jul 8, 2009
  • Jul 8, 2009
In my opinon, if it's free, why the hell not. That cam is a little much for your combo and you probably will lose a little down low, but plenty of people have done similar swaps and have had good results.
mustangsquared
828
new bern nc
Jul 8, 2009
  • Jul 8, 2009
I hate my E303....should have gone with the TFS 1... I have little low end grunt and at 2000rpms I can jump on her and theirs no real kick... not till 2500rpms then she will jump.
lincoln+ford
195
  • Jul 8, 2009
Ive got the 70mm throttle body and the car is being converted to mass air.And ive got a 3200 stall and either 4:10's or 4:30's are going in.Only because i dont drive the thing on the freeway ever.Id rather have it move out decent up to 50mph or so then be a freeway cruiser when i never ever will be seen on the freeway.Seriously i think its been 3 yrs since ive driven on the freeway.Otherwise if i do i just drive my escort since it gets way better mileage already which im not worried about mileage but id rather not turn my motor 3k rpms at 65 with the 4:30's
lincoln+ford
195
  • Jul 8, 2009
for the mark VII so just a 302,yeah stock rockers also will i need springs?And i thought the explorer intake would be a good match seeing is its pretty much the same as a gt40/cobra intake.
rock4451
20+ Year Stangneter
Nov 30, 2004
12
New Baden, IL
Jul 8, 2009
  • Jul 8, 2009
stock cam
lincoln+ford
195
#10
  • Jul 8, 2009
  • #10
Anyone hear of using the ls2 valve springs?
stykthyn
5,232
2,652
223
gainesville
Jul 8, 2009
#11
  • Jul 8, 2009
  • #11
I have heard of them being used, but I never read or saw a follow up. dont know how well they work. LSx springs(stock) are notoriously crappy anyway and are prone to valve float. get gt40 springs. they will handle pretty much any ots cam.
Cobra912
1,777
11
39
Wish I was anywhere but here
Jul 8, 2009
#12
  • Jul 8, 2009
  • #12
I would certainly give it a shot if you have it already. What's the worse that could happen with a small cam like that - you take it back out? worth a try
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 8, 2009
#13
  • Jul 8, 2009
  • #13
In the heavier Cougars and T'birds with the 5.0, Ford spec'd the Cobra cam because it gave a bit more low end torque to move the heavier car. That's one option. Another I'd explore is Comp Cam's XE258. Just be sure your heads have the appropriate springs for the camshaft you end up using.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jul 8, 2009
#14
  • Jul 8, 2009
  • #14
Mr. Yount, you still running around with the Volvo these days?
lincoln+ford
195
#15
  • Jul 9, 2009
  • #15
They handle .570lift stock sooo yeah.IDK im gonna call a few shops and see what they say.
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Jul 10, 2009
#16
  • Jul 10, 2009
  • #16
Stock cam
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
For Sale Ford 331 stroker engine for sale - with options!
  • TTSaleen
  • Jul 1, 2026
  • Engine and Power Adder
Engine and Power Adder Jul 2, 2026
Engine GT40P questions and advice
  • sav22rem22
  • Mar 11, 2023
4K
Fox 5.0 Mustang Tech Mar 31, 2023
sav22rem22
Can a stock computer on 94 95 Gt hold tunes for h/c/I
  • Farmstad
  • Nov 22, 2022
  • Digital Self-tuning Forum
5K
Digital Self-tuning Forum Nov 28, 2022
reddy351
Speed Density Combos
  • PistolGripSLR
  • May 24, 2022
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 4, 2023
Monkeybutt2000
M
