Good cam?
  • Thread starter Thread starter ms93gt
  • Start date Start date Aug 1, 2005
M
ms93gt
239
Bayville, NJ
Aug 1, 2005
  • Aug 1, 2005
I have 3 choices with blower cams. Setup is 306 with speed pro forged pistons, twisted wedge heads, heat intake, yada yada, and a vortech. Which would be best?
#1 Crane cam CCA-35-306-8, 2,000-6,000rpm, 224int/230exh, .533/.544 lift, 114 lobe seperation
#2 Crane cam CCA-35-312-8, 2,000-6,000rpm, 220int/224exh, .544/.560 lift, 114 lobe seperation
#3 Keep my trick flow stage 2 cam and advance it *4 degrees
I really need an answer soon. Which would make most power and be streetable?
I
IntenseBlue
946
  • Aug 1, 2005
I say choice #1
txstang84
1,639
42
69
Tuscola, tx
Aug 1, 2005
  • Aug 1, 2005
those are comp cams grind numbers, aren't they? I'm also looking for a blower cam, another guy on here recommended I ck out this site:
www.flowtechinduction.com
he said he had them spec him a cam and it's great to drive even though he doesn't have the huffer installed yet (i'll be dealing with the same thing-no blower upon initial install)
CrazyCobra
124
Ontario
Aug 1, 2005
  • Aug 1, 2005
What are the specs on this cam? Is it 224/232 .553/.563 with a 112 or 114 LSA? Also what is the intake center line of all 3 cams? What i'm getting at is, how is advancing the TF cam going to help when it is already quite similar to cam #1? I think, of the three choices given, if your TF cam has a 114LSA, I would stick with it and redegree it in to manufacturer spec. If it has a 112LSA it will still work well but #1 may be the better choice.
D
stock rocker arms breaking
  • Darwin1990
  • Sep 5, 2020
  • The Welcome Wagon
The Welcome Wagon Sep 5, 2020
Darwin1990
D
427w Engine Build
  • LuckyM95
  • Nov 12, 2016
17K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 11, 2016
LuckyM95
Na With 11r It Is - Need Help With Details
  • 89oem
  • May 3, 2014
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 4, 2014
89oem
N
302 sopercharger
  • N242
  • Mar 16, 2012
Fox 5.0 Mustang Tech Mar 16, 2012
N242
N
Engine Dead Cylinder, Broken Valvespring, Diagnostic Weirdness
  • MFE92
  • Aug 11, 2012
2K
Fox 5.0 Mustang Tech Aug 12, 2012
MFE92
