good cam?
  • Thread starter Thread starter undercnstrction
  • Start date Start date Sep 10, 2010
U
undercnstrction
312
  • Sep 10, 2010
so i came across this ad for a fox body, 302 cam on CL today. he's asing $100 for it, says it's never been installed in the car and needs to get rid of it due to putting a bigger motor in the car. can any of you translate what this means and tell me if it's a good cam for a "stock" 302 that, should i go that route, will end up with the typical bolt ons. any idea if it would be able to pass a smog check? oh yeah, i believe he said it's a trick flow cam if that makes any difference.
TFS-51402000
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,000-5,500
Intake Duration at 050 inch Lift: 221
Exhaust Duration at 050 inch Lift: 225
Duration at 050 inch Lift: 221 int./225 exh.
Advertised Intake Duration: 275
Advertised Exhaust Duration: 279
Advertised Duration: 275 int./279 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.499 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Valve Lift with Factory Rocker Arm Ratio: 0.499 int./0.510 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Grind Number: HR-224/339-2S-12
7-UP BILL
885
My other car is a Firetruck
Sep 10, 2010
  • Sep 10, 2010
It'll work on a stock motor ok. It' a little on the small side, will have a little "lope". It' s almost a cross between an FRPP "E" and "F" cam. I would try to get it a little cheaper though. Check your PTV clearances when installing any cam.
U
undercnstrction
312
  • Sep 11, 2010
would it be worth putting in or would i be better off coming up with a different cam? would it add much power?
Mustang5L5
Mod Dude
Feb 18, 2001
43,389
18,129
224
Massachusetts
Sep 11, 2010
  • Sep 11, 2010
It's a trick flow stage 1 cam. Popular cam, but on a stock 5.0 it's not where I would start
Trick Flow® Track Max® Hydraulic Roller Camshafts for Ford 5.0L: TFS-51402000 - trickflow.com
Cobra912
1,777
11
39
Wish I was anywhere but here
Sep 11, 2010
  • Sep 11, 2010
sounds like a good price if new in the box
U
undercnstrction
312
  • Sep 13, 2010
as always, thanx for the input.
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
M
For Sale Edelbrock Performer Ford cam and lifter set-429/460
  • My2001car
  • Dec 11, 2023
  • Other Classifieds
Other Classifieds Dec 11, 2023
My2001car
M
