Goodridge SS Brake Lines
I wanna get them too. They should always send all necessary parts for such an important part.
I emailed a question regarding torqe spec and life time to Goodridge and got 2h later already an answer :nice: :nice: :nice:. So it's OT, but just FYI:
Hello ...,
Thank you for your E-mail. To answer your question, these brake lines should out last your car. If for any reason they do have a leak or any other problem that effects their performance, we will replace them at no charge to you. All Goodridge G-Stop Brake Lines are Guaranteed for LIFE!
In terms of inspecting them, its a real easy process, just run your hand up and down the line several times. If there are any problems with the braid, you will know immediately! Its also not a bad idea to inspect the lines every so often, I usually do it when I rotate the tires every 15,000 miles or so.
To answer your last question about the torque spec, 14-18 foot pounds should seal everything tight @ the caliper end. We recommend starting with 16lbs and checking for leaks, increasing by 1 lbs as needed until a proper seal is achieved, DO NOT Exceed 20lbs! As for the chassis end of the line, you will need to refer to you Ford Repair manual for the proper spec.
I hope this answers all of your questions, feel free to contact me directly in the future for anything else you may need.
Thank you,
Michael Klapp
Technical/Customer Support
Goodridge USA
