Well I decided to put a Gords Heat Exchanger with fans in my car before the Kenne Belle gets installed. The install was a pain in the A$$ but the results were well worth it. The fans that come on the unit are SPAL fans that flow 330 CFM each so when you turn these suckers on they almost drown out the sound of the motor. Anyway here are the pics.
Here is the size comparison between the stock unit and the Gords Unit.
Front view
Front angle view
Fan Switch location
Front view
Front angle view
Fan Switch location
But seriously I have to build up the rear next. I have already ordered MJ's diff girdle brace. I have to then order some Level 5 DSS halfshafts and put new bushings everywhere in the rear. Then a new input and output shaft on the tranny. New flywheel and clutch for 26 spline inputshaft. And the list goes on and on. It's expensive to have a 10sec daily driven street car.
