. Then I would get gears and a Tuner, K&N drop in filter & a Tri-Ax or MGW shifter if you haven't already. If there is any left i would put the rest for gas money
j/k had to do it... Seriously though, if I could do it over again, I would have done the PI swap first. I've probably spent just as much money, if not more, on my mods and would get worked by a PI'd 96 - 98 GT. I am trying to get the funds together to do the PI swap soon, but owning a home and being married makes it really difficult to afford it.How do you figure the intake is a waste of money. Probably the most bang for the buck mod on an early 4.6L engine there is. Where else can you pick up 30+hp for around $200? If anything, I'd say the headers are the biggest waste of time and money in that equation. You'll gain next to "zero" horsepower on a NPI engine with headers and mid pipe alone! The exhaust ain’t coming out any faster if you're not getting the air in there to begin with!If I were you I'd save up more money and buy a Blower and not waste your time. But if you really really want to spend it now.
1st thing is to get some gears either 3.73's or 4.10's depending on how much hwy driving you do. Then a hand held tuner. Don't waste your money on an intake. If you feel like installing headers yourself those and a midpipe would be good. But if you pay for someone else to install your probobly spending most of that 1500.
If it were my money, I'd do a PI intake/Cam/Tune/Gear swap all in one shot, then start saving again and go with the a Centrifugal style blower next.![]()
Take into consideration too that the PI heads will help if/when you do a blower.
the most horsepower for my buck.
1. nitrous kit and gears
OR
2. save $500 more and buy a used supercharger kit
Mehh, not tremendously. A lot of blown NPI guys prefer the NPI castings for the power adder because of the combustion chamber design and the fact that the PI heads really don't flow that much better by comparison. Just swapping out the intake and adding PI cams will put you just about on par with a '99-up GT.Take into consideration too that the PI heads will help if/when you do a blower.
Listen To this Guy here! Knowing what I know now, I'd do exactly how he listed it. PI intake/Cam/Tune/Gear swap. Because you can't supercharge/ turbocharge after the PI swap due to the compression being 10.5: 1 Then after those mods save money then SC/TC it.
