Got A Good One Need Some Ideas...
  • Thread starter Thread starter MY 85 GT
  • Start date Start date Mar 11, 2015
First Prev 2 of 2
MY 85 GT
1,852
208
104
New Jersey
Mar 12, 2015
#21
  • Mar 12, 2015
  • #21
I have 42 lb injectors,pro-M MAF,340 lph fuel pump...the plugs haven't been changed in 3 years...also what should fuel pressure be set at for a starting point. I want to re-check that too....
MY 85 GT
1,852
208
104
New Jersey
Mar 12, 2015
#22
  • Mar 12, 2015
  • #22
Yes I have a wide band and meth injection.....too
Mustang5L5
Mod Dude
Feb 18, 2001
43,327
18,051
224
Massachusetts
Mar 13, 2015
#23
  • Mar 13, 2015
  • #23
MY 85 GT said:
ok did the engine run test here are the codes AGAIN I don't have an egr valve it blocked off....
here are the codes
11
31
42
92
and the o2 sensors are brand new also.....while engine was hot I didn't get an ACT sensor code.
Code 42/92 are O2 sensor codes, but those can be a result of how the engine is running due to a faulty sensor.
Did you wipe the codes and rerun the engine off codes (after getting the engine warm). Was the ACT and ECT codes still present? If one of thse sensors is bad (and creating a code) than that couple be the reason for the 92/42.
If i was you, i'd wipe the codes out. With the Innova 3145, when the codes are running, I beleive you hit the TEST button again to erase them. I'm not positive so check the manual. You basically hit one of the buttons on the unit after you initiate the engine off codes.
Then i'd go for a nice long drive get the engine nice and warm and then check the engine off, and engine running codes. If you still get an ACT code...replace it.
MY 85 GT
1,852
208
104
New Jersey
Mar 13, 2015
#24
  • Mar 13, 2015
  • #24
i dont have that code scanner i bought a different one i dont think i can clear codes with it so can i just clear them by disconnecting the Battery? then go for a long ride and recheck the codes your saying engine running or engine off?
Mustang5L5
Mod Dude
Feb 18, 2001
43,327
18,051
224
Massachusetts
Mar 13, 2015
#25
  • Mar 13, 2015
  • #25
Just disconnect the battery for 30 mins or to to erase the codes.
Upon startup, you will need to let the car relearn idle, so drive it around for a bit. Put a few miles on it and a few startups and shutdowns.
Then rerun the codes again. Run them with the engine off first, then start the engine and run it again. Should get two different groups of numbers
Reactions: MY 85 GT
MY 85 GT
1,852
208
104
New Jersey
Mar 13, 2015
#26
  • Mar 13, 2015
  • #26
Ok i will give that a try today or tomorrow weather permitting...rain i think tomorrow...
Quick question to what should fuel pressure be set at with Vac off....i think my friend might have moved it a little....
Mustang5L5
Mod Dude
Feb 18, 2001
43,327
18,051
224
Massachusetts
Mar 13, 2015
#27
  • Mar 13, 2015
  • #27
39 psi
Reactions: MY 85 GT
MY 85 GT
1,852
208
104
New Jersey
Mar 13, 2015
#28
  • Mar 13, 2015
  • #28
Thanks i will check that too...while im at it...i still think in my mind its dist related....or plugs..i want to change them or try the one side is near impossible to get to...
MY 85 GT
1,852
208
104
New Jersey
Mar 14, 2015
#29
  • Mar 14, 2015
  • #29
I changed the plugs yesterday a few looked ok...and a few didn't look that good..one was wet...also decided to change the ACT boy was that dirty and gummed up...took the car for a ride ALOT better still not 100% I did notice and intake manifold leak in the right front corner so im guessing the VAC leak isn't helping any....next on the list is fix the leak put my catch can system in, install my new rad and Throttle body...hopefully I can get it running right....I hope....
First Prev 2 of 2
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
  • dan50
  • Jul 18, 2026
dan50
