Okay, so as some of you have seen I just did my T-5 swap. I drove my parts car and the trans was perfect, no noise, no problems shifting.
I think my Tri-ax is bad. It makes a knocking noise in 1st 3rd and 5th. It won't go into 2nd at all, 4th and reverse are fine. Could I have a bad shifter? The stops are all the way out of the way and the shift lever seems to have clearence but I can't see everything with all the grease they put in there.
Other than that, I'm totally happy with the swap and thanks to those of you who gave me advice.
Edit: I forgot to mention the stock shifter seems to have gotten damaged once it was removed, I think it got used as a wheel chock by someone at my shop. It's too f'ed up to put it back on and be sure it's the shifter.
