got a RPM question
  • Thread starter Thread starter Cobain03
  • Start date Start date Jan 10, 2007
Cobain03
996
Lexington, Ky
Jan 10, 2007
  • Jan 10, 2007
i have a sunpro tach that is adjustable from 4 to 6 to 8 cylinders. what would happen if you are running it on a v8 with it in another setting? i have reason to believe that my tach is off and this is the only solution that i have come up with.
dodgestang
1,360
Cecil County, MD
Jan 10, 2007
  • Jan 10, 2007
If it was set to 4 it would read 2x too high.
If it was set to 6 it would read 1.5x too high.
Cobain03
996
Lexington, Ky
Jan 10, 2007
  • Jan 10, 2007
what if i said it was reading too low? i even have a dyno grap showing that the driver took the car up to a requested rpm (4200) while the graph shows around 5200.
Great68
691
Victoria BC
Jan 10, 2007
  • Jan 10, 2007
Then that would mean the tach is pretty inaccurate
BornInAFord
199
Bend, OR 97701
Jan 10, 2007
  • Jan 10, 2007
Dodgestang is correct... Personal experience: When I first got my 66, the PO had installed a tach that was set to the 6cyl setting instead of the correct 8cyl one. With the 3.00 rear, I calculated that I actually had a 4.11 comparing the tach readings vs the speedometer. When I was actually going 3000, the tach would read 4000 (and with the unfamiliar engine sounds I had no reason to doubt it). Being young and not so bright, I went ahead and bought a 3.55 track-loc as a replacement, thinking I was backing off on gearing... Although an expensive "mistake" I really enjoyed the new gears! Before I drove it, I counted the teeth on the old differential and realized my error. After a five minute corrective procedure, the tach has read accurately ever since. Not all tachs are accurate, though. For example, the mid-eighties factory tachs were notorious for not telling the truth.
Daniel
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Jan 11, 2007
  • Jan 11, 2007
Do you know how old your Sun tach is? Old electric tachometers are more likely to be off than the newer air core stuff like even the current $35 Super Tach II.
If it's a newer one, it's possible to adjust them by playing with resistor values inside, but it's not really an easy thing to do if all you want to do is fix a $35 tach.
On a side note, I took a newer Super Tach II and converted it to 1, 2, and 4cylinder operation. VDO gets $90 and Autometer charges $110 for tachs to do the same thing.
Cobain03
996
Lexington, Ky
Jan 11, 2007
  • Jan 11, 2007
could you all pinpoint things that could cause this?
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
1996 - 2004 SN95 Mustang -General/Talk- Oct 15, 2026
skidad
D
Yet another v8 swap
  • dulcimerbob
  • Sep 19, 2026
  • 3 4 5
2K
1974 - 1978 Mustang II Talk & Tech Yesterday at 8:33 PM
dulcimerbob
D
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
