most of you are wrong about the contour SVT...i just sold mine after having owned it for 3 years,so i do know a thing or 2...
first off it does have 200 hp.,and 165lb. ft. of torque...and it pulls hard from 4k to 7k....stock they run mid to low 15's...an svt contour will run as fast as a STOCK 94-95 AUTO gt,with the svt probably coming out ahead more times than not,and would pull on it as the distance increased all the way up to its 143 mph. top speed..(i know first hand my wife owned a 94 auto gt while i had the svt..now my lightly modded 95 gt 5 speed is faster..
also on a road course an svt contour will OWN alot of mustangs on this site on the curves...my 95 gt doesn't even come close to the handling of the svt(and its fwd)the csvt is a very nice drivers car,with enough pep to hang with alot of stuff...and to the comment about the civic with 160 hp beating an svt...i find that hard to believe it will beat a REAL svt with competent driver..
and to answer the original poster..you should easily beat any non svt contour whether it be a v6 or 4 cyl...as they generally run anywhere in the 16-18 sec. range in the 1/4...
but beware there are turbo's and s/c available,and the duratech v6 is a pretty solid motor,and lots have used a 50-75 shot with no problems at all...there are several svt's with turbo's running in the 13's and trapping at over 110 mph...if they could get traction would probably be in the 12's...not bad for a 4 door family car,that can handle the curves with the best of them..
