  • 1994 - 1995 Specific Tech
Got code 122....TPS below min voltage
  • Thread starter Thread starter Methodical
  • Start date Start date Sep 17, 2007
Methodical
1,192
11
59
Clinton, MD
Sep 17, 2007
  • Sep 17, 2007
What affect will this have on the car?
Stanger007
2,015
Baton Rouge, LA
Sep 18, 2007
  • Sep 18, 2007
Yes indeedy - I would guess it will have an incorrect transition from idle to cruise. The TPS will zero itself down to 0.48v. Anything lower and a code is thrown.
Say your TPS is actually at 0.30v. The lowest the PCM can go is 0.48v, so it will not read that the throttle is depressed until you are pressing the pedal enough to get to 0.48v.
I'd backprobe the sensor with a volt meter to verify what it is reading and replace if necessary.
Wes
Methodical
1,192
11
59
Clinton, MD
Sep 18, 2007
  • Sep 18, 2007
This is strange. I just check the TPS voltage - KOEO - and it was at .96v and goes up to 4.7v when opening the throttle blade. So why am I getting the 122 code? Strange.
Blackened302
1,439
South TX
Sep 18, 2007
  • Sep 18, 2007
hmm... maybe if you reset the KAM, see if it pops up after that.
Stanger007
2,015
Baton Rouge, LA
Sep 18, 2007
  • Sep 18, 2007
Check down the wires starting at the TPS connector to make sure nothing is shorting out. Did the voltage move up smoothly as you rotated the wiper?
After you do that, I like what Punisher said, clear the codes and see if it comes back again.
Wes
Methodical
1,192
11
59
Clinton, MD
Sep 18, 2007
  • Sep 18, 2007
Yeah I thought about resetting the computert o see if it comes back or not. I think I will try that.
I cleared the code with the scanner once and it came back but I did not reset the computer though.
Methodical
1,192
11
59
Clinton, MD
Sep 18, 2007
  • Sep 18, 2007
Stanger007 said:
... Did the voltage move up smoothly as you rotated the wiper?
Wes
I rotated the throttle blade and the voltage did rise smoothly.
R
TPS
  • Redguy69
  • May 5, 2025
1994 - 1995 Specific Tech May 5, 2025
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
M
Bad PCM?
  • MrPuffels
  • Jul 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 22, 2026
MrPuffels
M
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
