got my DF clutch - couple Q's
Saleen4971
664
Setauket, LI
got my centerforce DF clutch today! bought it brand new off an SVTP member for 275 shipped. came with the pressure plate and disc.
couple questions for you guys
why do the "weights" on teh fingers move? i assuem they are supposed to?
ford OEM TOB is best correct?
any better clutch forks out there?
do we have a pilot bushing or bearing in teh flywheel?
where is the cheapest place to get a fidanza aluminum flywheel, poly trans mount, adn aluminum D/S??
what sort of break in should i do with this clutch?
new flywheel bolts?
I hear that the Centerforce throwout is the way to go, if you have their clutch. I think it's even reccomended somewhere on their site. New flywheel bolts aren't necessary, just put some threadlocker on them when you reinstall. I'd reccomend getting a new pivot ball and clutch fork assembly, along with an adjustable cable and quadrant. That, combined with new tranny fluid and a good short shifter will make your trans feel like the most incredible thing in the world.
We have a pilot bearing. If you are using the stock flywheel, do yourself a favor and rent a pilot bearing removal tool. With a slide hammer and PB removal tool, you can quickly get the old PB out. The stock clutch release lever is more than adequate. The stock flywheel bolts will be fine, just use some red Loctite threadlocker.
The weights on the diaphragm springs are supposed to move. As RPM in increased and therefore centrifugal force is incresed, the weights slide out and provide more clutch disc clamping force.
From Centerforce:
Centerforce Recommends 450-500 Miles Of In Town Stop And Go Type Of Easy Driving Before Applying Full Power. If Your Driving Consists Of Mainly Highway Type Use, The Break In Period Should Be Longer Than The 450-500 Miles.
Centerforce has some nice billet aluminum flywheels.
well im gonan get an aluminum flywheel so i dont plan on removing the old pilot bearing. ill jsut get a ford OEM TOB, pilot bearing. i alreayd heav a steeda quad, adjsuter and shifter.
grab some GM synchromesh fluid, a crossmomber, an al d/s and an al/ flywheel and ooooooill be happy :)
Spend a few extra bucks and get the heavy duty Ford Racing TO bearing.
HD Ford Racing TO Bearing
BTW, it's cheaper at Summit.
*sigh*
i did not mean that the TOB pictures looked EXACTLY like a ford main bearing.
for5 some reason i had a brain fart and was thinking of a pilot bearing, not throw out bearing. i was thinking of a bearing that looks liek this:
what i saw a pretty much flat surface with no rollers/balls/whatever, it looked more like the style of bearing that a crank or cam bearing (pushrod cam. i realize that the 4.6 does not use traditional press in cam bearings) than it did a roller bearing.
i know what main bearing look like. i have had numerous motors apart before
