LoudToy958
V8SHME8 said:I totally figured I would get flamed for not recommending lakewood 50/50s. Glad to see someone agrees with me.
You car is getting pretty serious and getting to the point where driver preference comes into play alot. I will say that it seems you can never have enough caster on a mustang. So hopefully you got offset A arms. Your car is futher along then mine, but I am going to max out the caster when the time comes for my setup and my car is completely a street car.
What spring rates are you running? I am sure that you could benefit from an adjustable rear bar. EVM makes a pretty trick one that is cheap which you can use as long as you have sway bar mounts on your LCAs. Sometimes that TA can induce alot of understeer and you have to tune it out with a rear bar, but you would be the one to make that call not me.
Either way good look with the car, I am sure it already handles a million times better than it did.
I actually ordered the MM rear sway bar, mounts a little different, but I have heard a lot of great things about it. I change parts a lot, not sure I will like, but if I don't, I will sell it like the other stuff. I figured on offset a-arms. You are among a fleet of people who made that recommendation. Glad to know everyone is on the same page. With the MM K memeber, I can actually move the engine and tranny back 1". I have not heard if this is a good idea or not. Any thought on the subject? Seems like it would take a lot of weight off the front wheels and cause the car not to nose into the turns as much. As far as rates, I have 425 fronts, and 225 rears. I had 400 fronts, and 250 rears, and it was a little off. This new setup is much more satisfactory. I am, however willing to take other recommendations as always.
Deffinetly hope we can keep in touch here though. Not a lot of people into tracking cars. Most are just out for the 1/4 mile.
