Got my X3!
Shiroelex
There's nothing worse than aut
728
Westland, MI
I'm really excited. I just uploaded my aggressive 93 tune, and holy crap what a difference. It does make my car idle a little different though. I haven't gotten too in-depth with it yet, because I have been too busy screwing around out on the back roads. I just got LiveLink set up on my laptop, and was wondering what things you guys monitor with yours. I selected way too many things, and got alot of useless data. This should be one of the first mods people do! Right next to gears, of course. What should I watch with the laptop? :SNSign:
I would datalog(n/a) fuel pump duty cycle,maf voltage and counts, stft both banks,rpm coolant temp,load,throttle postion and of course spark timing.
good place to start
So whats the difference between this and an X2 that I currently have. I don't figure there is more power to be had. Just a bit nicer flash unit?
From what I understood,it has a 4 line display and can directly datalog to it without a laptop.I also have a x-cal2 and will net the same end result
you can datalog directly to the xcal 2. I have done it with mine. I keep a log file on it when I need to record a run or something. So its just more pretty display then. Definitally not worth trading up to then.
I can datalog directly into the X3 as well. I wouldn't bother trading up to it if you already have an X2, but if you're on the market for a new tuner and the Livewire is just a bit too new and expensive for you, then this is the way to go. It's definitely been easy as pie to use, and does way more things than I know what to do with yet. I really like it so far.
