got shafted
  • Thread starter Thread starter rockyracoon
  • Start date Start date Nov 27, 2010
1 of 2 Next Last
R
rockyracoon
874
27
49
margate NJ
Nov 27, 2010
  • Nov 27, 2010
I recently bought a rear (rotor to rotor) from a guy on craigslist,he told me that it was from his wife's car that had been hit bad in the front,and that he bought a shell and transferred everything over except the rear,which he pulled and held on to.well when I went to get it it seemed to rotate smoothly,so I bought it and proceeded to install it,after it was installed I weas turning the pinion flange and it locked up at the same spot,so now my spyder senses are tingling,and I pull the cover,and low and behold the ring gear has like 7or 8 teeth that are rusty.I pulled the carrier hoping it was just surface rust,but it seems like some of the teeth are pitted.so I call him and he says that all I need is a new ring and pinion,and that the housing and carrier are fine,which may well be the case,but im gonna have to spend like $300 bux for r&p and bearing kit.he totally screwed me.but I still know where he lives.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Nov 27, 2010
  • Nov 27, 2010
Whats the complaint here? Seriously anytime i have bought or used a "used" or "junkyard" rear end assembly i have had them rebuilt. There is no telling how long they have sat with or without fluid and what other contamination in there.
Stumbaugh
903
Russellville, Ar
Nov 27, 2010
  • Nov 27, 2010
You should have pulled the cover off of it before you bought it.
Crzyhrse
Seattle, WA
Nov 27, 2010
  • Nov 27, 2010
Throw the ring and pinion through his livingroom window.
Ateup
748
Nov 27, 2010
  • Nov 27, 2010
YEA, and poop in your hand and smear FU on his door!
Crzyhrse
Seattle, WA
Nov 27, 2010
  • Nov 27, 2010
That's alittle overboard.
Ateup
748
Nov 27, 2010
  • Nov 27, 2010
Dude, that is awesome...thanks for the real life LOL.
R
rockyracoon
874
27
49
margate NJ
Nov 27, 2010
  • Nov 27, 2010
the complainty is the fact that I was told that it was a low mileage rear in good shape.he never said anything like"it will need to be rebuilt" or "im not sure about how good it is" he said that it was a low mileage rear with nothing wrong with it.
if I wanted to pay to have one rebuilt I would have just plopped down $600.00 and have someone do it to the cars existing rear,but $150.00 seemed a lot better
R
rockyracoon
874
27
49
margate NJ
Nov 27, 2010
  • Nov 27, 2010
dude, what are you smoking ? whats so awesome?
Crzyhrse
Seattle, WA
Nov 28, 2010
#10
  • Nov 28, 2010
  • #10
You have to read between the lines. Like their would be an acceptable/not acceptable level of revenge violence.
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
Nov 28, 2010
#11
  • Nov 28, 2010
  • #11
You get way you pay for. I like to save longer and do it right the first time.
I wouldn't post stuff like that.
d98gt
4,505
59
204
SE Texas
Nov 28, 2010
#12
  • Nov 28, 2010
  • #12
I doubt he sold you a bad part on purpose
COBRA90GT
Mustang Master
Sep 22, 2001
6,654
HOCKEYTOWN ® , MI
Nov 28, 2010
#13
  • Nov 28, 2010
  • #13
Ding ding ding ! :Word:
Caveat emptor, especially with USED parts. Lots of dishonesty floating around out there among the various classified venues(Ebay/Craigslist/message boards, etc, etc).
Even if it wasn't the seller's intention to defraud you, OP, you should have performed due diligence and taken a few minutes to inspect the goods before agreeing to the swap - not a flame BTW, just stating a reasonable point, for both sides.
fast97gt
1,082
north carolina
Nov 28, 2010
#14
  • Nov 28, 2010
  • #14
i bring a tool bag and tools everytime i go to "purchase" used parts. if the seller fefuses to let me plunder at the parts i politly tell em to kiss off and look else where. imo you should NEVER take someones word on anything used, even "NEW" stuff now a days
Ateup
748
Nov 28, 2010
#15
  • Nov 28, 2010
  • #15
What he said. It was ironic that he told me my comment was over the top but it was perfectly acceptable to through the ring and pinion through his front window. I thought that was funny.
46stang
238
moorpark,ca
Nov 28, 2010
#16
  • Nov 28, 2010
  • #16
The rear end probably did work fine when he removed it but how long ago was that before you bought it. Moisture in the air can and will get into the rear end and cause some surface rust. Some pitting is perfectly okay as well when dealing with a used ring gear. Did you drive it and see if it was making noises or?? At $150 you still got a good deal imho. A new ring and pinion from summit is $150 and you got an entire rear end.
BurningRubber
1,865
24
58
Nov 28, 2010
#17
  • Nov 28, 2010
  • #17
#1 rule of Craigslist: Assume EVERYTHING on there is a scam, or the part is not as represented and proceed accordingly.
R
rockyracoon
874
27
49
margate NJ
Nov 28, 2010
#18
  • Nov 28, 2010
  • #18
ah its done and over with,old news I was just venting
M
motard1
17
#19
  • Nov 28, 2010
  • #19
Don't be cheap if you want UARANTEED *****. Buy new,or don't buy at all. If you stray from this,pay he consequences.
BurninRubb3r
45
#20
  • Nov 29, 2010
  • #20
Pretty much this. It is a risk buying from CL. I have had some ****ty experiences but hey, it happens and you just do your best to continue forward. I rarely use CL anymore because of all the low lifes selling junk on there.
1 of 2 Next Last
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Drive Shaft/Rear Diff Issue on 2014 GT
  • DudeStang
  • Jun 16, 2025
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech Jan 21, 2026
gkomo
C
Help identifying 8.8
  • Caden_H
  • Jun 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 12, 2025
limp
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
