got small quadrant gear on but....
  • Thread starter Thread starter slow88stang
  • Start date Start date Mar 31, 2004
slow88stang
144
St Albert AB
Mar 31, 2004
  • Mar 31, 2004
I finally got the small quadrant gear on its pin. There is now one problem, I cant figure out how to get the spring onto it now. Any suggestions????
ninety15.0
1,336
  • Mar 31, 2004
I assume your talking bout the clutch quadrant under the dash? first off i think there are two pins that the quadrant slides onto and then two cotter pins that hold it one there. Im not sure what spring you are talking about. if u could give us some specifics like what kinda quadrant it is and what spring your talking about im sure we could help some more. good luck man
StreetStang37
451
San Jose, CA
Mar 31, 2004
  • Mar 31, 2004
there is no way i was able to redo it on mine, i found putting the spring back on just about impossible, i just ended up buying a different clutch quadrant and adjustable cable.
blk92stangg
583
Hawaii
Mar 31, 2004
  • Mar 31, 2004
I agree with streetstang. When I converted to a aftermarket quadrant, I just about had to break the stock quad to get it off. I am thinking that the quadrant is installed on the metal dowel first and then pressed onto the pedal assembly.
slow88stang
144
St Albert AB
Mar 31, 2004
  • Mar 31, 2004
OK thanks guys...I have been informed that im going to have to remove almost everything....steering column, brake booster, and whatever else is in there. NOT A FUN JOB !!!!!
blk92stangg
583
Hawaii
Mar 31, 2004
  • Mar 31, 2004
Hey dude, that was my post you are referring to. I am not sure if you HAVE to take everything out to put back the stock one on, I was only commenting on what needed to be done to take out your pedals. Maybe if you try really hard you could do it with the pedal in the car. Any reason why you don't want to go with an aftermarket quadrant?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 1, 2004
  • Apr 1, 2004
The aftermarket quadrant can be installed without major disassembly.
Here's my experience with the FMS quadrant kit...
The under the car part was easy- getting the old quadrant off and the new one on was my problem. Look closely at the amount of clearance between the pivot shaft for the quadrant and the metal bracket to the right of it. You will need about 1" of clearance to slide the old quadrant off the shaft. Then take the ratchet mechanism off after that, if it didn't come off when you removed the quadrant. It may be inexperience on my part, but I had less than optimal clearance. I had to destroy the ratchet mechanism by drilling a pair of 1/8" holes like this - oo, the two 'o's are the holes drilled in the ratchet pawl parallel with the shaft. The holes are drilled in the part of the ratchet that pivots on the shaft. Then place a chisel inline with the holes to split open the ratchet pawl to get it off the quadrant .
The shaft for the quadrant pivot and the pin in the end of the clutch pedal MUST be perfectly parallel for the FMS quadrant to fit the first try – mine wasn’t and I had to enlarge the hole for the clutch pedal pin to get it to fit. Once you get to the cable, you will notice that the firewall end has an ear on it with a small hole in the ear. I recommend that you seat the cable against the firewall, line the ear up so that you can drill a hole in the firewall and use a sheet metal screw to secure the ear to the firewall. This will hold the cable in place while you adjust the cable. The rest is fairly easy. When you take out the front seat, put a large piece of plywood or a metal plate over the seat mount studs so that you don't tear up your back while scooting around under the dash.
MUSTANGJOE
Silver Stanger
1,644
17
59
Apr 1, 2004
  • Apr 1, 2004
Damn is it that hard to install a quadrant? I thought it was a regular bolt on! know I have to drill and what not. I was gonna but one but im changing my mind listening to all these things.
ss93cobra
1,422
Wilmington NC
Apr 1, 2004
  • Apr 1, 2004
No drilling required bud. Its not a tough job as long as you buy the aftermarket version vs. the stock style. It takes about 30-45 minutes to put one in even if you work slowly. Not a big deal. Go ahead and buy one, you'll be glad you did since it can't strip out on you like the plastic factory junk.
Blk91stang
607
North Brunswick, NJ
Apr 1, 2004
#10
  • Apr 1, 2004
  • #10
Yup, I did a BBK quadrant and cable.. Took about 2-3 hours to do only cause I took my time to do it right and not break anything. I did not remove anything but the drivers seat so I could lay down for 2 hours. Sure its a pain but once its done... its done!
MUSTANGJOE
Silver Stanger
1,644
17
59
Apr 1, 2004
#11
  • Apr 1, 2004
  • #11
if you buy the aftermarket ones you dont have to remove the little gear or is it a different set-up? thanks guys
slow88stang
144
St Albert AB
Apr 1, 2004
#12
  • Apr 1, 2004
  • #12
Holy ****.....Finally after about 5 hours of playing with the little spring, ITS ON!!!!!! YAY YAY YAY Im soooo happy that its done
StreetStang37
451
San Jose, CA
Apr 1, 2004
#13
  • Apr 1, 2004
  • #13
you do, but i thought the whole thing was a simple enough, pretty easy, about 1 hr.
slow88stang
144
St Albert AB
Apr 1, 2004
#14
  • Apr 1, 2004
  • #14
Now all of that terrible work made me a very very happy person. That quadrant just fixed the **** right out of my clutch. It works like its a brand new car !!!
MUSTANGJOE
Silver Stanger
1,644
17
59
Apr 1, 2004
#15
  • Apr 1, 2004
  • #15
witch kit did you use?
slow88stang
144
St Albert AB
Apr 1, 2004
#16
  • Apr 1, 2004
  • #16
I put a new stock one in...I dont suggest using it unless you really really want to. I only used it because that is all I could get in the time frame that I had to work with.
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Interior and Upholstery HVAC Mode selector vacuum switch issue.
  • parish99
  • Jul 3, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
KAWMAN2
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
