Got the lowering springs on. (H&R SuperSprots)
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Just the front lowered. Didnt like it.
And all 4 corners lowered. LOVE IT.
I havent really ridden around yet but the ride should be better than stock.
Its about time! :D
Big improvement! The ride should feel alot firmer. Take it around some tight bends, you'll be amazed at how well it will stick to the pavement (just don't go nuts on public roads).
88stangnut said:
That looks pretty good!.. what did those run you?? how is the ride vs stock?
I know your are talking about his but mine ride alot better than stock, except on hard bumps they rattle you, but not as bad as the stock stuff would.
And I got mine for $80 shipped. :D
hey how long did it take you to swap yours out? also what way did you do the front?
i disconnected the swaybar endlink, removed the caliper/rotor, disconnected the strut then slowly let down the A-arm (had a jack under it)
the rear took me 40 mins from getting out the jack to TQing the last lug nut and the front was like an hour and 40 mins for the first side and just under an hour for the 2nd
I did the front the same way. It took me a while to do the first front side cause I didnt undo the swaybar link and got the spring in a bind. it took a little over an hour for the other front, and about an hour for the entire rear.
Heres a write up I did showing exactly how I did it.
http://www.automodding.com/install-lowering-springs-94-t1449.html
yea the endlinks were a little tough to break loose, but once lose they came right out. i replaced mine with some new urethane enegery suspension ones since the ones in there were all torn
diablostang said:
Who told you I was running H&R's on my car, poser????
JK ya :D Looks good. :nice: I actually have the H&R Race springs, not the SuperSpRots
:lol:
now I just need a 347 and to paint my car black.
