granada brake help
ONEBADPNY
195
FREMONT, NEBRASKA
i just did the granada disc brakes swap on my 66 coupe. i have a rattle coming from the pass side caliper or something that i can not figure out. going over a bump it rattles like crazy but pushing on the brakes it goes away. everything looks good to me but i'm lost? anyone have an idea?
I would first check your anti-rattle clips and the "lock screw" things that hold the caliper. I don't know the correct terms as you can see. I did the granada swap on the '65 so I know what they look like!!! Big help huh? It sounds to me like you have a loose caliper and when brakes are applied, the pressure holds the caliper still. It could be a couple things though. Make sure to check the bearings and lug nuts for proper torque.
