Granada Rotor Issue
  • Thread starter Thread starter Power Surge
  • Start date Start date Dec 14, 2004
Power Surge
1,516
Palm Coast, FL
Dec 14, 2004
  • Dec 14, 2004
Anyone with the Granada rotors have a problem with the lower control arms hitting the rotors? Mine are hitting at the very inside edge of the rotor face. I could grind the very edge of the arm down to fix it, but am curious if it's a common issue first. Maybe my lower ball joints are toast too, I'll have to check those, although I don't recall them being bad when I did the new uppers.
1badII
796
Durham, North Cacalaky
Dec 14, 2004
  • Dec 14, 2004
I don't have Granada rotors yet, but tubular upper control arms will probably solve your problem.
C
cobraii351
1,104
Altoona, PA
Dec 14, 2004
  • Dec 14, 2004
I've heard that this can be an issue. I didn't have any troubles. I did have new ball joints in before I did the swap though.
Tim
J
jshcobra
720
  • Dec 14, 2004
I recall that problem when I swapped Granada rotors onto my Cobra many years ago. As I recall, I purchased a large machine washer (1/16th" thick) that slipped onto the spindle behind the rotor and that cured the problem.
Power Surge
1,516
Palm Coast, FL
Dec 14, 2004
  • Dec 14, 2004
Ok thanks. I don't mind "fixing" it, I just never heard anyone mention this issue.
cobra_2_76
201
Norwalk, Ohio
Dec 14, 2004
  • Dec 14, 2004
Mine bolted right up with no clearance problems. I replaced all the suspension components at the time.
Personally I would be nervious spacing the rotor out with a machine washer, but then again I could just be paranoid too.
Dave
A
a351Must2
Windsor II
4,317
Snohomish, WA
Dec 14, 2004
  • Dec 14, 2004
I've done it twice and had to "clearance" the end of the lower control arms both times.
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
T
Resolved Steering won't return to centre
  • Tom77
  • Apr 28, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2025
Tom77
T
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
