granatelli control arms
You're right - most will chime in supporting MM, and I do too. I have the SFC and they're made really well.
I haven't read anything on granatelli CA's, but that price is really low compared to Steeda or MM. I wonder if the quality will even be close?
*EDIT*
There's a recent thread on granatelli's plennum - I'd IM the guy and see how he likes the quality... although I'd invest more money in UCA's / LCA's than a plennum
stangliter04 said:
nice :nice: what are your other suspension mods?
I have intall suspension technique coil spring,the other mods are in the front
steeda offset A-ARM bushing
steeda bumpsteer kit
steeda X2 ball joint
energy suspension off set rack bushing
steeda 4-bolt caster camber plates
Can i intall theMM LCA EVEN if i don't have the MM UCA,i plan to buy these soon,but was wondering if i will be able to feel a difference with only the LCA for now.
you can install them now. when you do get the UCA's you wont really feel a difference when they are installed. make sure you get the steeda UCA's that look like the stock Ford ones, no adjustables
What is the difference between steeda UCA and heavy duty UCA from ford racing? they seem identical but steeda ask $100 and ford $65:shrug:
all steeda did was weld on a cross brace on the bottom
