Anyone N/A running one? I know a tune would be needed, but even N/A with stock TB a larger MAF would increase volume as well as velocity??? Is this correct, or am I still thinking 5.0? LOL
Apprec. any info
Apprec. any info
It does appear to look as though he took the same recalibrated MAF sensor that's included with his cold air intake and somehow was able to fabricate it to fit inside of a 90mm MAF Lightning meter, so perhaps it may be possible and even if it is ? chances are that if you plan on using a hand held programmer ? you might as well forget about it because the tuning files are calibrated for the factory MAF electronics..Therefore his MAF sensor is completely useless, unless you have no intentions of planning any future modifications that require the use of a programmer....
