definititly sounds like axle seal.remove diff cover,remove axle c-clip for the side that leaks,pull off the brake caliper,remove rotor,slide axle out.seal is located within axel tube near the end of the tube.when installing seal be careful to not damage it by bending it etc.use something the same diameter when putting a new one back in.good luck!fairly easy job.
