Great - PATS problem
jg22
26
I have a 96 cobra and am having a bit of a problem and I believe it is with PATS.
I lost the main keys so I called a locksmith to cut me some new ones. Got that done and tried to do the manual program of the keys (insert key, wait 45 min for theft light to stop flashing etc.)
That doesnt work tho because the theft light only flashes rapidly for roughly a minute and does not display any codes after that either.
I had another locksmith come that said they could use a computer to program new keys. He said he was able to see the previous keys that were programmed and he was able to clear them to program the new ones BUT he wasnt able to do this because it would not recognize the new keys for programming. He suggested it was a bad pats antenna.
So i replaced the pats antenna with a new one and the theft light is still flashing rapidly with no codes. Used a meter to check for breaks in the wiring and all checked out good.
I'm thinking my last options are the stealership or a tuner to bypass pats. Any one have any suggestions, I am at a loss for words now.
It might help if you posted exactly what you did to re-program PATS. The manual procedure must be followed exactly to work. Unless you post the exact steps performed, we can't double check your work.
Never reprogrammed pats, didnt know a way to do that or if that would even help
It's at Ford now and I asked for a quote to just replace everything, that should fix it right?
But he refused and insisted I instead pay the hourly rate to trace for a problem in the wiring because replacing the whole system may not fix it
Wow, my head hurts. You just need to get new keys and have them programmed for your car. No need to replace anything. Ford obviously knows how to do it, and can certainly do the job. Since the car is there now, you might just want to let them handle it. There may be others who can program keys as well.
In the future, you may want to consider keeping 3 programmed keys around. To program a new key without going to ford, you need at least 2 keys, so that allows a spare in case you loose one.
wmburns may know more tricks than I, but that is my understanding and what is typically explained in the owners manual.
Thats the thing not ford nor any locksmiths are able to program the keys
Ford wants to charge me $89 an hour to look for a problem in the wiring
The Locksmith told me about a lady the brought her mercury to the dealer for the same type of situation and it was 2 and a half months before they figured out what to do, needless to say I'm not too confident in just paying the hourly labor til they figure it out, that will end up more than the car is worth lol
So I was wanting them to possibly just replace the entire pcm/pats because I've read that is roughly $1000 for thrm to do and would certainly fix the problem correct?
Rather than them search for the problem while I'm paying $89/hr just for them to tell me it needs replaced anyways
Idk just my train of thought right now but I could be way off in my thinking, it's stressing me out
