  • SN95 4.6L Mustang Tech
Griiinnddinnnnnn
  • Thread starter Thread starter 02bluegtstang
  • Start date Start date Nov 2, 2006
02bluegtstang
Banned
Aug 27, 2006
Los angeles, california
Nov 2, 2006
  • Nov 2, 2006
Ok so everytime I start my car in the morning and when the engine is still cold I have a hard time going into reverse...I first have to put it in first then Im able to go into reverse....then once Im driving and shift to second it almost doesnt want to let me go into second and you can hear it grind...why does it do this...once i drive for about 5 mins and the engine has warmed up the grindin goes away....
what should i do? will my extended warranty cover this problem?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Nov 2, 2006
  • Nov 2, 2006
Adjust your clutch and check your trans fluid. If your fluid has been changed recently its provably the wrong weight. If a fluid is too heavy, when it is cold it will cause problems shifting.
Dusstbuster
I love meat more than anything! I just have a spec
May 31, 2004
1,462
33
64
Moorhead, Minnesota
Nov 2, 2006
  • Nov 2, 2006
Without owning a manual tranny and going only off of what ive read previously, i'm going to guess that your car has a Tremec 3650 in it? If so it's telling you it's on its way out I believe...
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Nov 2, 2006
  • Nov 2, 2006
Thats a very common problem for the Tremec TR-3650. The infamous grind
the98stang
2,408
Clovis, CA
Nov 2, 2006
  • Nov 2, 2006
You have nothing to worry about. ALL t45's/3650s do that because there are no synchro's in the tranny. You to put it in first gear and then try reverse. Or move the car forward a lil while in first gear.
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
