  • SN95 4.6L Mustang Tech
GRINDING NOISE FROM REAR!
  • Thread starter Thread starter specTAKular
  • Start date Start date Oct 16, 2006
specTAKular
18
Chicago
Oct 16, 2006
  • Oct 16, 2006
I have been experiencing a slight, but very noticeable, grinding noise from my passenger side rear. It only occurs when going from a standstill when the car is under load (i.e. my 260 lb. buddy or heavier) on the passenger side. I have had the differential fluid changed and gears were fine. Seems to be something more like a bearing.
Anyone else have a similar issue or can help me out with this?
Thanks in advace!
Jsun3701
124
Virginia
Oct 16, 2006
  • Oct 16, 2006
Had the same problem, couldnt narrow it down. Had the entie rear end replaced. It went away. But that was under warranty so didnt care about the cost. Maybe a wheel bearing / axle bearing?
ex-pjs snake
Virginia
Oct 16, 2006
  • Oct 16, 2006
+1 Agreed.
specTAKular
18
Chicago
Oct 17, 2006
  • Oct 17, 2006
Thanks guys, i'll look into that.
Do you know how difficult of a job this would be to swap out? Are there any 'special' tools needed?
Shiroelex
There's nothing worse than aut
728
Westland, MI
Oct 17, 2006
  • Oct 17, 2006
It's kind of tricky. You have to pull all of the brake hardware off, unbolt the brackets, drain the differential and remove the cover, push axles in and remove c-clips, remove axles, then remove bearings with a slide hammer and rear axle bearing removal tool. If you're brave, you can tap the bearings in like I did with a big 4x4 hub nut socket and a rubber mallot, or get one of those bearing/race installer kits. You'll know if it's a bearing, if you raise up the back of the car, and the tire has alot of movement front to back and up and down. I believe it might be something else though. Are you lowered at all, and do you have steeper gears installed?
specTAKular
18
Chicago
Oct 17, 2006
  • Oct 17, 2006
No, not lowered at all and gears are stock. Had a mech. mention that there may be something grinding on the drivetrain so i'm going to try and jack it up to take a look under there in the next couple days.
any other possible thoughts are welcomed!
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
C
strange noise coming from rear wheel
  • crazyone64
  • Oct 28, 2025
SN95 4.6L Mustang Tech Nov 26, 2025
squeak93
Rear end noise while driving low and high speeds
  • skkrtis
  • Apr 7, 2025
2005 - 2014 S-197 Mustang -General/Talk- Feb 9, 2026
Broncin491
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 5:36 PM
AeroCoupe
