Ground cable help!
grumpy5.0
28
Car died today, no power or anything. Found out the grounding cable to negative battery was loose. Am trying to find a spot to hook cable up to. So far nothing has worked. Used a bolt/nut got at home depot, attached to bracket under battery. HELP!!!!!
As you found out, the engine to block ground is critical. Here are some more things to check while you are looking at grounds.
A screwdriver points to the bolt that is the common ground point.
The battery common ground is a 10 gauge pigtail with the computer ground attached to it.
Picture courtesy timewarped1972
Correct negative battery ground cable.
56567d1230679358-positive-negative-battery-cable-questions-86-93-mustang-oem-style-ground-cable.gif
