Well I am going insane. I just purchased/installed a pair of CDT components for the front, and have been fighting what I'm guessing is a ground loop for days now.
Here's what I'm running:
Pioneer DEH-P6500 head unit
Legacy 800w 4ch. amplifier
CDT Audio HD-62EF components
Polk Audio 12" sub
Stock rear 6x8's
Stock ford amp running the rear 6x8's
With the car off:
I get no whisling/buzzing from the factory rear 6x8's that are run off the factory amp, but get definate interference (no whisling) from the fronts and subwoofer. The only way I have found to cure this is to touch a grounded wire to the RCA terminals on the back of the head unit. This eliminates all unwanted sound and everything sounds great. But should I HAVE to have this little ground wire to get rid of this problem, or is something wrong that needs to be addressed and not just band-aided?
With the car on:
I get no whisling/buzzing from the factory rears, but I do get the same buzzing, accompanied by the whisling that rises with rpm. This is also through both the sub and front stage...and is only reduced when the ground wire is applied to the head unit's RCA terminals.
I have tried a power line filter on the 12v line to the head unit with absolutely no reduction in noise, period. I have checked, and double checked the ground wire to the amp...and am sure it is good. I have also tried another amp I have just to make sure my current amp isn't bad, and it is not. The head unit is only a couple months old, and I cannot understand why it would be bad...but I have not tried another head unit, yet.
The RCA's and speaker wire to the front stage are run down the center of the car away from the 1/O welding cable that goes to my battery in the trunk. I don't think they could be picking up interference, however I guess anything is possible.
Only thing I haven't tried (besides a different head unit) are some high $$$ RCA's, as I haven't fully convinced myself that this is the problem. If it WAS the RCA's, I would expect to get the noise only with the car on, and get no static when it is just on battery power. Am I wrong here?
I don't remember having any kind of this problem with the factory door and dash speakers, and if I did it was hardly as noticable as this.
Any ideas would be greatly appreciated. Next step is to take it to Ultimate Audio, bend over, and tell them to figure it out.
Thanks in advance!
Polk Audio 12" sub
Stock rear 6x8's
With the car off:
With the car on:
Thanks in advance!
Maybe having the amp turned up so high is pushing it's limits? Now that I have been able to get rid of the wine for now, the amp will click over to protection if I crank the radio up. I'll try turning down the gain and letting the head unit do alittle more work (use it's low and high pass filters instead of the amps) and see how that does.
