ground strap connected to under hood insulation?
331 stang91 said:
So I took the insulation piece from under my hood off. There was a ground strap connected to it that went to the hood hinge. Is it needed or was it only needed if you have the insulation on?thanks
I don't know if it's needed (I would think so), but you can just reuse one of those tabs that held the blanket in place, and pop it right back in the hole only without the blanket.
About the only thing I can think of where it might be needed: I assume the under hood light uses a mercury switch (I have no idea - many cars do use one however). I wonder if the wire is for that.
Good luck.
If you are talking about this strap? Then no. Used only
Sn95's use a cable which is similar to this
