Grounding issue?
86SilverFox
Kentucky
1986 LX 5speed
Had an issue for awhile but don’t drive much. Everything works as it should and drives fine. When I turn on the headlights the seat belt buzzer stays constant, both turn indicators and bright light indicator lights up, tach and fuel gauge stop working. Instrument cluster lights do not work but fuse is fine. I and not knowledgeable in electrics at all.
Any suggestions?
I have had no luck locating what is causing the issue. All ground I can find seem to be good. Located this today. The 2nd wire coming out of #2 spot on the instrument cluster goes no where. The black and green wire is intact but the black is not? Car was originally a v6 but now is v8 and has a ford performance fuel injection harness.
