  • SN95 4.6L Mustang Tech
Grounding Kit
  • Thread starter Thread starter rockmanxl
  • Start date Start date Aug 3, 2004
R
rockmanxl
39
  • Aug 3, 2004
Does anyone have one or know exactly what advantages they are supposed to give? I see them all over the net for around 20 dollars and they say they give about a 2% HP increase along with better throttle response and such, is this legit? Thanks for the help
9
98SteedaStang
382
Chicago Suburbs
Aug 3, 2004
  • Aug 3, 2004
A what?
madmatt
Ellis Juan sympathizer
465
Lexington, SC
Aug 3, 2004
  • Aug 3, 2004
I believe this is a more popular upgrade on imports, but doesnt it have something to do with your ignition? Oh well, 2% increase on our cars is like 5.2 flywheel horsepower, so about 200 dollars for about nothing sounds GREAT! I dunno, just sounds like a waste to me. I have however heard good things about the plasma booster, so maybe look into that.
Turbo92PGT
746
Auburn Washington
Aug 3, 2004
  • Aug 3, 2004
Basically what it is is about 10 pieces of 2-3 ft long 4-8gauge wire. You attach them to things like your alternator, your valve covers, your engine block, your ignition coil etc. Then it comes with a metal piece that is a central ground and grounds all the parts said above. Just doesn't seem like it'd be worth all the wires running all over my engine.
R
rockmanxl
39
  • Aug 3, 2004
Actually madmatt, its not 200 dollars for the kit, it is only 20 dollars, so 5 HP to the flywheel for 20 dollars is not that bad.
54life
392
Cali currently at Ft. Rucker AL
Aug 3, 2004
  • Aug 3, 2004
i heavy seen steady dyno runs netting 5 hp to the wheels on this one.
3,287
24
69
Broke
Aug 3, 2004
  • Aug 3, 2004
A BS mod IMHO. Get pulleys, gears, a chip, mid pipe etc. etc. no-one uses that junk for a reason. Thats a waste of 200 bucks.
AdRock
521
South Texas
Aug 3, 2004
  • Aug 3, 2004
Read above again. It's $20 not $200. and you can build them cheaper than thet if you buy the pieces seperately yourself. I had a nice setup on my last car and it cost a total of $11 to do it.
The setup helps the car have a better and cleaner ground. This helps the entire electrical system, not jus tthe ignition. But yes for as cheap as it is to do it it's worth it. The trick is finding the best mounting points.
R
rockmanxl
39
  • Aug 4, 2004
before anyone else posts anything in this thread.... TWENTY dollars... not TWO HUNDRED dollars... thats a big difference guys
I
i_eat_rice(rs)
28
Spearfish SD
Aug 4, 2004
#10
  • Aug 4, 2004
  • #10
my roomate just installed a grounding kit on hit car.....a power gain is unnoticable of course but throttle response is definatly improved......takes about an hour to install and IMO is definatly worth the 20 bux.
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
