GT-40 heads
  • Thread starter Thread starter Justin111
  • Start date Start date Dec 8, 2011
J
Justin111
31
  • Dec 8, 2011
Hi,
I pulling my engine out of a 88gt. It has mild bolt ons ie. full exhaust, 65mm throttle body, 70mm mass air, electric fan.
Are gt-40 heads worth messing with? I could get a set out of a explorer at the local junkyard for $120.00 and my shop works with a local machine shop that could clean them up cheap.
What do I need for them? as far as valves springs and such. I plan on going pretty much stock. I have a explorer intake and injectors. Also the person I bought the car from said there was a aftermarket cam in it but I not positive.
Thanks,
Justin
screamin5oh
170
centerville oh
Dec 8, 2011
  • Dec 8, 2011
yes they are deff worth using, i would get the trick flow spring upgrade kit, use your stock injectors on the explorer intake
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Dec 9, 2011
  • Dec 9, 2011
id pick up a set of 24's and a MAF also...
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Dec 9, 2011
  • Dec 9, 2011
Maybe your local machine shop can help them flow a bit more as well. I'd look into that too. They are decent heads, with some machine work they can be much more.
srtthis
5,129
1,666
204
Maryland
Dec 9, 2011
  • Dec 9, 2011
yup... deck them around .020" to get the compression up and open them up a bit
Reactions: VibrantRedGT
rbonella
409
@ home
Dec 9, 2011
  • Dec 9, 2011
I agree with above...you can make those heads move some air with a little work. But old TW heads or RPM heads are pretty easy to come by and they will always be a little ahead of GT40's when it comes to flow....I'd grab to GT40's, but be on the look out for other heads for sale
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
