GT-40 intake hood clearance?
  • Thread starter Thread starter 95redvertGT
  • Start date Start date Feb 20, 2009
9
95redvertGT
  • Feb 20, 2009
I am about to install a gt-40 intake into my 95 GT. I believe I have to remove to strut bar but there are replacement ones to use with the gt-40. I am wondering if i will still have clearance to use an aftermarket crossmember with the stock hood. Also, if there is room to use a 1 in spacer and crossmember. Lastly, any suggestions on an elbow adapter to use with the gt-40 and 70mm throttle body? Thanks for the help
D
DavidNC
119
  • Feb 20, 2009
The gt40 intake will fit with the right after market stb. The explorer version will require cutting down the front bolt flange to keep the bolt head from rubbing.
It will not fit with spacer.
9
95redvertGT
  • Feb 23, 2009
Its the tubular gt40. What elbow did you end up running with your intake?
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
G
Hello and Instrument Wiring
  • GT Jon
  • Jul 5, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 6, 2026
Mustang5L5
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Engine 95 mustang Gt
  • Bett23
  • May 29, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 29, 2025
General karthief
