GT-40P Guys.... Roller rockers?
Grits
SEE!! I do have a neck!
2,013
Colorado Springs, CO
Hey all.. putting together a very simple performance engine build... I have a 99 explorer engine, with GT-40P heads and explorer intake... i want to run a E303 cam...
Now, i want to go ahead and upgrade the valve springs and retainers while im at it..
I was looking at using the Ford Racing M6513A50 single valve springs and retainers.. as they are supposed to work with all GT-40 heads..
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=44
Good or No?
now im kinda confused on the rockers... will the stock rockers work? or do i need to upgrade? can i get a reccommendation if so? as i dont know what the explorer heads came with compared to the tipical E7's on the mustangs and/or if the rockers are the same.
Thanks
Stock rockers will work. I run a set of scorpion 1.6 pedestal mount RRs. If you decide to run a set of 1.7s remember to recalculate the valve lift to make sure that your springs will still work with them.
Just last weekend I put a set on my brothers car, we used some the stock cam and a 1.7 RR. Using 1.7's with your e-cam will put you at .529 valve lift. Looks like those frpp springs arent recomended with the stock rockers. I hear people using the TFS spring kit with good results also.
