GT-40p Head/Explorer Intake Discussion
DFG 5OH
1,341
Louisville, KY
I'm getting some P heads with a 3 Angle Valve Job, and an Explorer Upper and Lower. I want to run an E-303 cam, 1.7 RR's, 190lph fuel pump, AFPR, 65mm TB.
I do have a few questions. With the new setup will my torque be gone? I'd love to have more grunt up high, but i'd like to keep the low end as well. If i'll lose most of my low end, i'll just get gears :D. Also, would long tubes, or shorty's be better? I'm running a stock bottom end, and am hoping for 250+rwhp, in the future with some porting and stuff, 300!
What size MAF should i get to bring a few ponys to the new setup? I'm keeping 19#ers with a 190 fuel pump and an adjustable fuel pressure regularor.
I'll be asking tons of questions, so i'll try to keep it all in this thread. Please feel free to suggest differnt supporting mods.
Matt
I have a VERY similar combo, i'm running a 73mm C&L with 24#'s, 3.55 gears and all that stuff you listed (cobra intake instead of explorer :rolleyes: )
Anyways, teh low end torque is DEFINATELY there!!
It'll easily roast them all the way through 2nd gear (on 7inch wide turbines, lol)
I wouldn't woory about the low end. I have been driving my car around for a week now and I have a little MORE low end and ALOT more top end. I do have 4.10's though, but either way, I felt an increase everywhere. I just went to the track with my 315 nitto drag radials and I spun quite a bit through second, hurting my time. I installed my cam straight up too. If you are worried about low end, advance the cam like 2 degrees.
Also, as far as the MAF, if you are keeping the stock injectors, I wouldn't even get one. It may cause you to need a tune and it's alot of money for not that much power.
Matt
Your goal for the combo will require more fuel than 19's can support and more air flow than a typical 19lb caled maf can meter.
Just go for 24's & matching caled maf when needed so you don't waste money. Until then, the stock inj's & maf will be fine.
I'd go for the 255lph intank fuel pump over the 190lph.
When you do need a maf, I'd go for a ProM 77 or 80.
Later
Grady
FWIW...my last dyno was with an 93 Cobra upper to see the gain from the previous Summer....I run Thumpers/19 cam...all the base mods for heads...anyway I opted to stay with 19s to see what gives..I run a 190 also....
I was told by alot of people that my AFR would tell me if the 19s were being maxxed.....did 3 pulls and never touched a thing...AF ratio was on the money From my last dyno....timing was 14 with 38 lbs from the prior dyno....Guy said don't touch nothing....
I lost 15 lbs tq with the upper from a stock Tmoss lower, but gained 12 ponies with the intake and 1.6 RRs...
I run a long Pro-77..
263 RWHP 295 TQ was where it came in...
I have a Accufab 75 and 24s waiting to go on..If I feel game this year I'll throw em on to see the dif...My 77 is cal'd for 19s so I gotta get a chip to add em though...
I don't doubt anything you have said and you've got the data to show your 19's are getting the job done but I wanted to just throw in my .02 cents worth as they say.
I do think you are at the limit of those 19's or your close to it.
Based on inj duty cycles of data logs some of the other self tuning guys have told me about, I have come to think the limit for 19' is about at the 265 to 275rwhp range at stock fuel pressure. Seen a few threads with dyno results of lean ratios to give me that train of thought as well.
If you up the pressure you can push em a bit farther to be sure.
Another thing to consider when looking at inj size is those formulas quote fwhp and us Stangers always think in rwhp. There is a difference!
Each combo is different and some reach the limit of the stock 19's sooner than others. The ability or efficiency of the combos parts to move air is a big factor and the amount of error in the maf's transfer curve is another factor that will cause probs also, which again, is different in each combo.
You don't wanna be too lean and unfortunately, the condition that it happens at is max load and max rpm :bang:
IMHO, this is an aera where its better to be safe than sorry.
Later
Grady
I'm running the stock inj. wich i assume are 19's? I have it cammed and have the fuel pressure set at 45 psi. to keep the A/F in check, i also have a 255 intake pump. When i did the C&L 76 they had to turn reposition it a little to make it run right. Meaning we turned it counter clock wise to get it to run a little better. But when i took off the head's they were wet in some cyclinder's so i was told i have plenty of fuel? So if this is the case then hopefully i wont run into any issue's when i slap the new heads and intake on ? peace
john :p
